View Poll Results: What is your closest, current tire size?
Stock
10.56%
31x10.5
43.99%
32x9.5
2.00%
32x11.5
11.29%
33x9.5
0.73%
33x10.5
6.01%
33x12.5
17.21%
35x12.5
6.65%
Larger than listed
1.55%
Voters: 1098. You may not vote on this poll
What size tires are you running? (IFS Only)
Old Sep 25, 2006 | 11:07 PM
  #141
Bear80's Avatar
So the Den's still open eh, Cibolo creek got shut down and is part of the park now. Hey so who is this OBOR and their torsion bars??
Old Oct 5, 2006 | 08:50 PM
  #142
SoiledGreen98's Avatar
Brand new today BFG Mudders 265/75. I got a full inch+ of lift over 265/70 BFG rugged trails. I had to bash the pinch welds into place. Now I get to see what else rubs when i take it out on the weekend.
Old Oct 5, 2006 | 08:51 PM
  #143
Old Oct 5, 2006 | 10:39 PM
  #144
SwampThing's Avatar
OBOR is short for Outback Offroad (off wurzbach parkway by blossom). Do damn good work. Their torsion bars were something that they fabed up and were experimenting with. Was able to turn up 4", but the ride was so stiff you'd nearly get launched from your seat from a speedbump, and it made the steering horrible. Plus it screwed with the CV angles, and without bj spacers and whatnot it's nearly completely useless to turn up past 2" (which stock can do anyways), so they scrapped the idea. Had to throw em out cause I bent the hell outta one side somehow when goin muddin a while back.
What part of cibilo creek you talkin about, I was just back there... Not the part down off Eisenhower and Holbrook by Ft. Sam Houston right? But yeah the den's still open, but it's gotten pretty well known by the local authorities. Been muddin out at Turkey Creek over by the Spring Branch area. Think it wins hands down over the den.
Old Oct 6, 2006 | 05:53 AM
  #145
sschaefer3's Avatar
28's and I can and have taken it through 4/5 stuff out here in Arizona. The fact that is has an e-locker out back and the ARB RD90 from my 99 4Runner means alot more than tire size. It's also stock, no lift, stock shocks and springs.
Old Oct 6, 2006 | 06:38 PM
  #146
Where are those pics at? I'm down south, in Tucson, and am starting to run out of new places to wheel.
Old Oct 6, 2006 | 06:54 PM
  #147
sschaefer3's Avatar
Upper Woodpecker, Florence Junction, Arizona.
It is a difficult trail. All of the other trucks, every single one, were on 35's and locked front and rear.
My Mini was also locked front and rear.
Old Oct 7, 2006 | 05:58 AM
  #148
HAVOC's Avatar
31X10.5 BFG mud terrain. (with no susp. or body lift)
Want to put 35's after I install the lift.
Old Oct 8, 2006 | 04:00 PM
  #149
go-play-outside!'s Avatar
31x10.5 15 I'd go bigger but i'm not sure how big to go without some kind of a lift.
Old Oct 9, 2006 | 01:16 PM
  #150
craw4x4's Avatar
I'm running 265/75 16's on stock suspension and yota alum. wheels
Old Oct 9, 2006 | 02:32 PM
  #151
Homestar4Runner.com's Avatar
31-10.50 Wrangler MTR's 1.5 HD Downey springs in the rear.
Old Oct 16, 2006 | 12:35 PM
  #152
vwfastg60's Avatar
36/14.5/15's M/T's
pic
Old Oct 16, 2006 | 04:10 PM
  #153
YOYO82's Avatar
I have 33x12.50 on my 82 4x4 toyota truck with no lift.
Old Oct 17, 2006 | 09:38 PM
  #154
Sonofmayhem's Avatar
Thats not ifs
i do too though
Old Oct 18, 2006 | 04:46 PM
  #155
Christyle's Avatar
16" rim tires, forget the size right now, but roughly a 33x10.5 i think, maybe a bit wider and a bit shorter than that. Mounted to chevy z71 alloys (5.25" backspacing ) And they rub a lil. Mostly on the idler arm when turning hard left in parking lots and such. Rear flexs into frame and hits the bedsides a little, ripped off the plastic molding pieces in the front of the wheelwells. Need to do some rear trimming. Already hammered the front pinch weld and trimmed the bottom a little. Make the truck look 100x better though.
Old Oct 23, 2006 | 04:26 PM
  #156
TinyTruck's Avatar
88 Stock gears, 4in of "custom" lift, 35x14.5 boggers
88 Stock gears, 4in of "custom" lift, 40x17.5 rear 40x14.5 front
Old Oct 23, 2006 | 09:59 PM
  #157
SwampThing's Avatar
Ohhhh puuurrrddddyyy
Old Oct 29, 2006 | 06:23 AM
  #158
mattman por vida's Avatar
i'm running set of 5 33x14.50 Swampers (TSL radials)
Old Oct 30, 2006 | 09:11 PM
  #159
91TPU's Avatar
31x10.5 BFG All Terrain KO's...stock, but working on it
Old Oct 31, 2006 | 07:28 PM
  #160
914runnerswap's Avatar
have 31x10.5 bfg ats mounted on steel for off road, 23575r15 on alloy for road
