View Poll Results: What is your closest, current tire size?
Voters: 1098. You may not vote on this poll
What size tires are you running? (IFS Only)
#167
j944 love the 5 dollar bill in the rims .... i plan on going to 265x75x16s i think ill get the bfg a/t's i had a set on my last toyota and they did great in the mud and they where bald too
#172
I'M RUNNING SUPER SWAMPER 38" 15X12.5 I HAVE A TRAIL MASTER 4" SUSP LIFT & 3" BODIE LIFT . TIRES RUB ON STEEP INCLINES BUT NORMAL DRIVEING THEY ARE FINE, I JUST BOUGHT RANCHO TORSHION BARS AND WILL GIVE ALITTLE MORE LIFT IN THE FRONT AND WILL GET SOME REAR SHACKLES TO LIFT REAR AND SHOULDN'T RUB ANY MORE.
#173
why dont you talk like the rest of us....
#174
31x10.50 Bridgestone Dueler MTs....hands down the absolute best tire I have ever bougt. Have had then almost 5 years...on 2 different Toyotas..on 2 different witdth of wheel(stock yota and 10 inchers) and have over 30,000 miles on the and still wearin smooth. Gonna replace them this spring before the are too smooth to run...but they will get me thru the winter. I would buy them again...but it seems Bridgestone has discontinued them so I guess I will; be trying the Firestone Destination MTs.
#176
right now im runnin 32x11.5 bfg a/t ko's with a 4" pro comp stage 2 lift and 411 gears.by the end of the month will have 5.29s and rancho 9000 5 way adjustibles hopfully by the end of next month 35x12.5 bfg a/t ko's 5 speed 201000miles daily driver
#177
I'm running 35x12.5R15 Goodyear MT/R's on my '90 4Runner. It's got a 2" body lift, 4" Trailmaster up front, 4" Procomp in back, and Rockstromper balljoint spacers. Surprisingly, the 22RE does quite well (I am running 5.29 gears though).
#178
With my stock 15x8 aluminum wheels, running 33x10.5s TA/KOs and BJ spacers, I have about 1/2 inch of room between the inner sidewall and upper A-arm.
I've seen a few others running 33x12.5s and BJ spacers - how much backspacing do I need to do that??
m/t radial claws
