View Poll Results: What is your closest, current tire size?
Voters: 1098. You may not vote on this poll
What size tires are you running? (IFS Only)
#142
Brand new today BFG Mudders 265/75. I got a full inch+ of lift over 265/70 BFG rugged trails. I had to bash the pinch welds into place. Now I get to see what else rubs when i take it out on the weekend.
#143
#144
What part of cibilo creek you talkin about, I was just back there... Not the part down off Eisenhower and Holbrook by Ft. Sam Houston right? But yeah the den's still open, but it's gotten pretty well known by the local authorities. Been muddin out at Turkey Creek over by the Spring Branch area. Think it wins hands down over the den.
#145
28's and I can and have taken it through 4/5 stuff out here in Arizona. The fact that is has an e-locker out back and the ARB RD90 from my 99 4Runner means alot more than tire size. It's also stock, no lift, stock shocks and springs.
#147
Upper Woodpecker, Florence Junction, Arizona.
It is a difficult trail. All of the other trucks, every single one, were on 35's and locked front and rear.
My Mini was also locked front and rear.
#155
16" rim tires, forget the size right now, but roughly a 33x10.5 i think, maybe a bit wider and a bit shorter than that. Mounted to chevy z71 alloys (5.25" backspacing
) And they rub a lil. Mostly on the idler arm when turning hard left in parking lots and such. Rear flexs into frame and hits the bedsides a little, ripped off the plastic molding pieces in the front of the wheelwells. Need to do some rear trimming. Already hammered the front pinch weld and trimmed the bottom a little. Make the truck look 100x better though.
