What is this plug??
Old Jan 23, 2016 | 06:48 AM
FinallyOffRoad's Avatar
What is this plug??
I was looking around my 3VZ-E looking for vacuum leaks, missing plugs, etc, anything that could be causing problems. Anyway, I looked down to the right side of my block down near where the oil filter is and I saw this dangling plug that just looks like a wire attached the a cup. Anyone know what it is and where it goes?
I pulled it up to see it better. It was dangling down.
Old Jan 23, 2016 | 07:05 AM
k-ray's Avatar
That looks like the oil pressure sending unit plug.
Old Jan 23, 2016 | 07:15 AM
scope103's Avatar
It looks a little like the connector to the oil pressure switch. Do you have a gauge or light?
Clean up the wire and get the color (hard to tell from an iffy picture of a grimy wire). It looks a little like black with yellow stripe, but that should be IG1 (or IGF), and that makes little sense on a connector like that. I show the oil pressure sender as Y-L (yellow, blue stripe).
Old Jan 23, 2016 | 07:20 AM
It's white with a blue stripe. Ahhh. I see. I looked at the plug and it's a slide on plug just like the pressure sending unit has, so I'm pretty sure that's it. I just bought this truck with no knowledge of what had been done, but there's a new oil pressure sending unit in the glove box, so I guess he started, but didn't finish. Thanks!
Old Jan 23, 2016 | 07:24 AM
Do you know where I can check a model number to see if this is the right one? It's a Beck/Arnley KG-1102
Old Jan 23, 2016 | 07:38 AM
Here's a side by side. The threads are the same and the connectors are the size, they're just different sizes.
Old Jan 23, 2016 | 07:51 AM
Nope. The sensor is too short and the plug can't reach it. Oh well. I don't even know if the old one is bad.
Old Jan 23, 2016 | 07:57 AM
MudHippy's Avatar
It looks pretty bad. That's for sure. I would make the wire longer.
Old Jan 23, 2016 | 08:50 AM
You think it's okay that the new one is much shorter than the old one? It won't send wrong pressures or anything? Even to the old sensor, the wire is pretty tight, so I wouldn't mind lengthening the wire regardless.
Old Jan 23, 2016 | 08:54 AM
scope103's Avatar
It looks pretty bad. ....
Oh, I don't know ...
... Do you have a gauge or light? ...
Which is it? If you have a gauge and use the sender for the light, it will wreck the gauge.
Beck Arnley says 201-1649 for the gauge, 201-1798 for the gauge (I used 1994; I don't know your year and it might make a difference on the plug.) Beck Arnley says "nope" to KG-1102. http://www.beckcatalog.com/
If you have, oh, an '88, RockAuto calls out a Beck Arnley 201-1130 (for '92 and earlier) IF you have the light.
Tofer
Dec 11, 2015 03:48 PM
kryptik
Jul 12, 2005 10:39 PM
