What is this plug??
I was looking around my 3VZ-E looking for vacuum leaks, missing plugs, etc, anything that could be causing problems. Anyway, I looked down to the right side of my block down near where the oil filter is and I saw this dangling plug that just looks like a wire attached the a cup. Anyone know what it is and where it goes?
https://cimg1.ibsrv.net/gimg/www.yot...e4405c931.jpeg I pulled it up to see it better. It was dangling down. https://cimg3.ibsrv.net/gimg/www.yot...ac2c7c965.jpeg |
That looks like the oil pressure sending unit plug.
It looks a little like the connector to the oil pressure switch. Do you have a gauge or light?
Clean up the wire and get the color (hard to tell from an iffy picture of a grimy wire). It looks a little like black with yellow stripe, but that should be IG1 (or IGF), and that makes little sense on a connector like that. I show the oil pressure sender as Y-L (yellow, blue stripe). |
Originally Posted by scope103
(Post 52306020)
(Post 52306020)
Here's a side by side. The threads are the same and the connectors are the size, they're just different sizes.
https://cimg8.ibsrv.net/gimg/www.yot...7124387cd0.jpg |
Nope. The sensor is too short and the plug can't reach it. Oh well. I don't even know if the old one is bad.
It looks pretty bad. That's for sure. I would make the wire longer.
Originally Posted by MudHippy
(Post 52306029)
(Post 52306029)
It looks pretty bad. ....
(Post 52306020)
... Do you have a gauge or light? ...
Beck Arnley says 201-1649 for the gauge, 201-1798 for the gauge (I used 1994; I don't know your year and it might make a difference on the plug.) Beck Arnley says "nope" to KG-1102. http://www.beckcatalog.com/ If you have, oh, an '88, RockAuto calls out a Beck Arnley 201-1130 (for '92 and earlier) IF you have the light. |
