What does this connector / sensor do ?
Old Apr 13, 2021 | 06:17 AM
PremiumOctane's Avatar
Hegy guys this connector / wire was broken off in my 1987 22R Pickup engine bay. The connector is close to the thermostat housing. It had a green wire with red stripe. Any ideas on what this is for ?
Old Apr 13, 2021 | 10:05 AM
az4x4runner's Avatar
Looks like possibly 22R coolant temperature switch connector. Does it look like it would plug into this?
https://www.yotashop.com/temperature...9-89428-20050/
Old Apr 13, 2021 | 10:11 AM
That is probably it, here is a pic of the sensor on the engine
Old Apr 13, 2021 | 10:16 AM
Yep, that looks like it on the left.
Old Apr 13, 2021 | 10:20 AM
Now i just need to find a replacement connector with wire since the wired sheared off on the existing connector. Anyone know where to get a new one or am I junkyard shopping ?
Old Apr 13, 2021 | 10:25 AM
My guess is junkyard, but maybe someone else will know a source. You could temporarily crimp on a spade connector if you need to drive it.
Old Apr 13, 2021 | 10:57 AM
Just did the spade connector for now, I will keep searching to see if i can find the original connector. Thanks for your help !
Old Apr 13, 2021 | 01:01 PM
87-4runner's Avatar
Joey at the 4runner house may have one, if you can get him to answer a phone call or text.
Old Apr 13, 2021 | 03:21 PM
scope103's Avatar
You have the connector body (and it looks in pretty good shape). That is the hard part. All you need to do is extract the current pins (you probably just need a tiny screwdriver), crimp new pins onto your wires, and insert them back into the body. You might have to extend the wires (but probably not).
Okay, that doesn't sound trivial, but it sure beats roaming the wastelands of Pic-U-Part.
Old Apr 14, 2021 | 06:22 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Here's a good picture of the tab that locks iit into the connector. You just need to slide something down to flatten it out so the terminal comes out. This photo was taken from Eastern Beaver's website. I get my Yazaki terminal ends from them. Fantastic quality. Takes 1-2 weeks to get, but very reasonable on price.
Old Apr 20, 2021 | 08:30 PM
Neemox's Avatar
The little black rubber seal in the back of the connector (where the wire used to come out) was actually pretty dang easy for me to remove when I had to fix similar. Just pry out the rubber and you'll be bale to see in there and get a better idea of what you are up against. When you put it back in, maybe add the tiniest amount of RTV to the rubber to make it seal real good again.
128keaton
Nov 30, 2021 06:06 AM
rodskwad
Aug 7, 2012 10:40 AM
nv4runner
Feb 8, 2008 10:19 AM
tampabayota
Mar 7, 2007 05:24 PM
the_supernerd
Jun 28, 2006 11:44 PM
