Well, I broke my truck again....
Old Mar 24, 2006 | 07:00 PM
Yamaha+Toyota=Fun's Avatar
This time my 3rd member decided to break. 2 or 3 teeth broke off the pinion gear. The ring gear is a little chewed up but no teeth broken off that. Anyone have a clue why the pinion gear would break like this? Also, does anyone have a spare 3rd member they could sell to a poor high school student for cheap?
Pics will be up soon....
Old Mar 24, 2006 | 07:15 PM
Some carnage for your enjoyment....
Old Mar 24, 2006 | 07:32 PM
msw0085's Avatar
have a story to go with that carnage?
Old Mar 24, 2006 | 07:38 PM
Accually it just broke on my home from work... it started making noise about 200 feet from my driveway luckly. I have been wheelin my truck pretty hard lately though...
Old Mar 24, 2006 | 08:50 PM
91_4x4runner's Avatar
Sucks pretty bad that it happened, but lucky for you that you werent 400 miles away.
Old Mar 24, 2006 | 10:25 PM
Also if anyone has part from a 4cyl 3rd let me know. I might be able to get one going if i can get a hold of a few certain items.
Old Mar 24, 2006 | 10:27 PM
superjoe83's Avatar
aren't those gears pretty new? what brand were they?
Old Mar 24, 2006 | 10:35 PM
I bought the 3rd already setup, it came out of someone elses truck so who knows how old or what brand they are. There was quite a bit of backlash in the gears when I got them, so that may have contributed to their failure.
Old Mar 25, 2006 | 04:01 AM
ZUK's Avatar
ZUK
The pinion tooth profile is stronger than the ring tooth. To do what happened to you is probably either the pattern was set-up way too deep....or the pinion was slopping around(loose/wobbly). Were you leaking gear oil out of the pinion seal?
Old Mar 25, 2006 | 08:54 AM
Thanks for the input. No leaking at the pinion seal at all.
Zuk do you have any extra 4.88 thirds lying around you could sell for cheap
Old Mar 25, 2006 | 07:29 PM
93Toyota PU's Avatar
Check out ebay item #8049666234. $145 for bolt ring and pinion.
Old Mar 26, 2006 | 03:17 PM
I would be willing to trade someone my good working aussie locker for a 4.88 3rd.
Old Mar 26, 2006 | 07:58 PM
Asha'man's Avatar
What's a 3rd member? Front diff?
/n00b
Brian
Old Mar 26, 2006 | 08:08 PM
On IFS trucks there is a 3rd in the rear axle, on SFA trucks there is one in the front and rear. It bolts up to the axle housing, and contains the ring and pinion gear.
Here is a pic.
http://www.diffcutaxles.com/Inventaire/Toy_4_10.gif
Old Mar 26, 2006 | 08:27 PM
92runnersr5's Avatar
i may have one but im not sure, ive read that the v6 auto with the 31s have that axle. will that aussie fit the 4 cylender as well if so id gladly send it to ya! i live in eastern canada
Old Mar 26, 2006 | 08:56 PM
never mind i just checked my code... i dont. sorry
Old Mar 27, 2006 | 03:49 PM
What gear ratio do you have?
voiddweller
19
May 2, 2016 09:10 PM
rbravo1
Jun 29, 2015 01:34 PM
WI Girl
Jun 25, 2015 03:45 AM
paxanders
Jun 21, 2015 06:29 AM
Corey
Jun 10, 2002 04:23 AM
