weird vibrations?!?!?
Old Jun 17, 2009 | 11:35 AM
Matt94's Avatar
OK guys i have a question and im driving my runner sr5 v6 manual ill accelerate the vibrations dont happen but when i hold a speed the truck well start vibrating not bad but noticable and when i let off the gas it starts shakin even worse(in slower speeds -45).. its not in the engine i can rev it up and they is no vibration. i just got new tires(5,000 miles ago), could it be a weight. its not gettin worse should i be worried.
and happens in all the gears
Old Jun 17, 2009 | 11:49 AM
Lumpy's Avatar
Could be tires I guess...is the vibration coming from the steering wheel? Can you feel it in your feet or in your seat?
Could be a U-joint...I'm leaning more towards that. If it were the tires I would think that you'd feel it weather you were accelerating or cruising. When the U-joints go they'll start to vibrate at different times depending on how the torque is.
Best educated guess I can give.
Old Jun 17, 2009 | 12:03 PM
scuba's Avatar
I think thats about as bad as norbert.
Old Jun 17, 2009 | 12:23 PM
Matt94's Avatar
when it vibrates its everwhere in the rear view and in the column
Old Jun 17, 2009 | 12:30 PM
Lumpy's Avatar
I'd start with the u-joints. I don't think its the CV's could be...
Old Jun 17, 2009 | 02:52 PM
yoterr's Avatar
x2^^^^
Old Jun 17, 2009 | 04:45 PM
buckz6319's Avatar
Well it could be any number of things ..what is the year & miles on the 4runner? I'm assuming that it is the 4runner in your signature?
Bad motor mount or mounts, transmission mount, wheel bearings loose or bad, bad ball joint or joints,shocks,cv joints,drive shaft out of balance,
muffler, bad fuel filter,bad fuel pump
just some things to think about
Old Jun 17, 2009 | 07:12 PM
Matt94's Avatar
94 4runner and it has 175,000 miles on it..
but it stops vibrating when i take it out of gear
Old Jun 17, 2009 | 07:48 PM
jtruck79's Avatar
i may be stupid but i did run into this issue with a nissan 4x4 x cab i had and i lost the carrier bearing on the driveshaft. do those runners have 2 piece rear shafts>>>
Old Jun 18, 2009 | 05:58 AM
Lumpy's Avatar
Taking it out of gear will release the tension/pressure on the shaft and will allow it to turn freely. This may cause the vibration not to be felt.
Old Jun 18, 2009 | 07:06 PM
mattaway's Avatar
a u-joint is like $15. if that don't fix it, take it to the place you had the tires mounted, complain about your truck vibrating ever since the new tires were installed and demand a road-force balance.
you'd be surprised how many brand new tires don't pass road-forcing.
Old Jun 19, 2009 | 03:47 PM
Matt94's Avatar
alright thanks
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
