weird stuttering/jolting at low rpm's
This just recently started happening. When I shift gears a little early and expecially up hills I get a few big jolts at about 1500 rpm's. It is different then shifting early and getting the shakes, this is a major series of jolts. It goes away shortly after 1500 rpms. It feels more like the tranny is slipping again and again, or a cylinder not firing or something like that. At any rate it never did it before.
I do have a squeal coming from my clutch/tranny that my mechanic told me was my throw bearing needing lube, so I hope that is what is causing my jolts.
Anyone have any idea as to what is happening?
Motor Stuttering /Jolting
Sounds fishy , if its not the motor then maybe you have a drivetrain problem , driveshaft center bearing , u-joint maybe , could be alot of things , need to try and find if it is your drive train or motor somehow
Hmmm. The engine doesent rev up when it happens, so guess the trannys out then ? It doesent rev at all, it is more like it wants to stall for like half a second then you get the jolt, then it accelerates with that jolt for about a second, and repeats with the stall. The jolting gets gradually weaker as I approach 1500 rpm's then is gone and engine runs fine, but at 1000 - 1200 rpm range it is very noticable and has me concerned now. It used to be able to chug along during a early with relative ease, but now I have to shift higher and give it more gas then regular to get it to stop doing that.
Do all that and rule out the motor , compression will show bad HG or Burn't / cracked / broken valve as well .
Rule out the motor then look to your tranny .
And if so have you checked it to see if it has any cracks in it or loose clamp , Idle the truck and if you have one open the hood while running and squeeze the Intake Air Tube all over and see if the motor stumbles or stalls , I have seen this before as well from that problem , just something real simple it could also be ........rule out the motor hehe
If that is bad then when you torque the motor it will run like crap and sometimes not recover very well .
Thanks I'll try to do what I can I guess till I can get enough cash together to get my mechanic to look at it. I'm the mean time I just gotta drive faster to avoid it, oh and today I noticed it doesent do it in 4 wheel drive. So gotta drive faster and go wheelin...
we will just beat this dead horse but let me know what your mechanic finds out
, hope its something simple
icentropy
Jul 14, 2015 10:23 AM
