Vsv
Old Aug 28, 2020 | 07:22 AM
4Runner_3.0's Avatar
Vsv
I need some help. would anyone please point me towards a solution. I was servicing my Air Conditioning line (High Side) on a 1990 Toyota 4Runner 3.0 and I broke off the bottom portion of the VSV looks like a little plastic cylinder. I buttoned everything up on the A/C and went to try and start up the engine so I could add R12 into the vacuumed system, now my truck wont crank. It makes like a gurgle sound if I keep the key turned in the on position. Sounds like possibly the fuel canister. Not sure why or if ever I had heard this sound before. Everything was fine before I began working on the. Truck started just fine. We recently went on a beach trip. Could the broken VSV be the problem? Why would this cause my engine to not even crank? I did remove the battery to create more work space and the front grill. Does't look like I yanked anything out of place.Thank You!
Old Aug 28, 2020 | 07:51 AM
scope103's Avatar
Originally Posted by 4Runner_3.0
. ... Could the broken VSV be the problem? Why would this cause my engine to not even crank? ...
No.
The starter is electrical; if it won't turn, you almost certainly have an electrical problem. Start by confirming your battery is charged. Then, you want to make sure electricity is getting to the starter -- particular the solenoid lead. The starter is hard to get to on a 3VZE, so I'd carefully remove the starter relay (under-hood junction box) and check for battery voltage on the corresponding sockets (the top of the relay is labelled.)
... I broke off the bottom portion of the VSV looks like a little plastic cylinder....
To me, none of the 7 VSVs look like a cylinder, but they do pretty much all look the same. But you know which one you're going to have to replace.
... so I could add R12 ...
Where on earth are you getting R12? And how much are you paying for it?
Old Aug 28, 2020 | 01:31 PM
Melrose 4r's Avatar
5 Year Member
You can easily purchase R12 on ebay.
Rithsleeper
Jul 30, 2019 02:03 AM
92ehatch
Feb 8, 2015 03:55 AM
91Toyotatruck
Apr 30, 2014 08:06 AM
pinstripe_chuck
Dec 1, 2013 11:14 AM
jener8tionx
Jul 18, 2013 12:51 PM
