valve tap
valve tap
i have a 90 pickup with a 22re. theres a weird tapping sound that seems to be coming from m valve train. the noise increases with higher rpms. i tried the lucas oil stabilizer, it helped a little. any suggestions on how i should approach this problem?
If you think you have a valvetrain noise the first thing to do is to check the valve clearances and set them to spec.
While you have the valve cover off you can inspect the timing chain and guides
And when it goes back together, don't overtighten the valve cover nuts as this will make the valves noisey.
_Nicco_
Sep 21, 2015 03:06 PM
LotOMiles
Sep 14, 2015 11:45 PM
idadan208
Sep 7, 2015 09:06 AM
