valve tap
Old Feb 25, 2008 | 10:31 AM
joshuapc's Avatar
valve tap
i have a 90 pickup with a 22re. theres a weird tapping sound that seems to be coming from m valve train. the noise increases with higher rpms. i tried the lucas oil stabilizer, it helped a little. any suggestions on how i should approach this problem?
Old Feb 25, 2008 | 10:33 AM
MMA_Alex's Avatar
have you adjusted the valve lash? do a search on valve adjustment, and you'll find a ton of info.
Old Feb 25, 2008 | 12:44 PM
joshuapc's Avatar
no i havnt adjusted it yet. just lookin for sum suggestions before i take apart my engine. would any body recommend some other mods or sources of the problem?
Old Feb 25, 2008 | 01:00 PM
Targetnut's Avatar
If you think you have a valvetrain noise the first thing to do is to check the valve clearances and set them to spec.
While you have the valve cover off you can inspect the timing chain and guides
And when it goes back together, don't overtighten the valve cover nuts as this will make the valves noisey.
Old Feb 25, 2008 | 01:16 PM
jason191918's Avatar
Fuel Injectors?
Old Feb 25, 2008 | 01:57 PM
keithguts's Avatar
Originally Posted by jason191918
Fuel Injectors?
I 2nd that as this was my problem. I also no that if the valve covers are to tight, it will cause tapping as well.
Old Feb 25, 2008 | 04:06 PM
joshuapc's Avatar
thanks a lot for everyones suggestions! damn things irritating!
Old Feb 25, 2008 | 06:28 PM
joshuapc's Avatar
what do you mean by fuel injectors? they make a tapping noise?
Old Feb 28, 2008 | 08:11 PM
turner01's Avatar
when you guys say that over tighting the valve cover bolts can cause taping...how does that work? just curious
Old Feb 29, 2008 | 01:02 PM
MMA_Alex's Avatar
the rocker arms tap on the shield thing inside of the valve cover.
_Nicco_
Sep 21, 2015 03:06 PM
Obmi
Sep 16, 2015 02:13 PM
LotOMiles
Sep 14, 2015 11:45 PM
Corvoid
Sep 14, 2015 10:10 AM
idadan208
Sep 7, 2015 09:06 AM
