turbo questions
Old May 4, 2007 | 07:10 AM
CyMoN's Avatar
turbo questions
well my buddys G/F has a 87 turbo auto she let it run out of oil yesterday and the motor is seized up this truck did not leak oil too bad but the turbo would suck a quart down every 2 weeks or so
so now he is looking at having the motor rebuilt and removing the turbo altogether will what will he need to do to leave the turbo out from the rebuild
dose he nee a new ECU?
will he need diffrent piston heads or are the turbo ones ok to run?
any ideas are welcome
thanks
Old May 4, 2007 | 07:31 AM
ewong's Avatar
turbo moter has lower compression...
so NA 22RE has higher compression pistons..
Dunno about the ECU... probably run OK if you leave all the sensors...
Old May 4, 2007 | 10:13 AM
RD1970's Avatar
Turbo
Im converting my truck over to turbo if your interested I'll trade you all the non-turbo stuff for your turbo stuff?
(ecu, exh manifold, injectors ect.)
Old May 4, 2007 | 04:15 PM
CyMoN's Avatar
I can ask him but I have all of the stuff to run it regular
Old May 4, 2007 | 06:12 PM
Bill's Avatar
The ECU is very different
here's the basic run down of stuff you will need to change:
Pistons
head
injectors
Injector plugs
ECU
exhaust manifold
Intake piping
emissions junk
Rad(or simply soder the turbo pipe closed/off)
You will also need to block off the oil feed.
Old May 4, 2007 | 06:26 PM
slacker's Avatar
I'd say your better off selling that motor as a "turbo core" include wire and ECU and picking up a new core and such from a wrecker .
Old May 5, 2007 | 07:14 PM
Bill's Avatar
Probably the best idea.
There are enough little oddities between the two that it would be cheaper and easier to start from scratch.
Old May 6, 2007 | 08:18 PM
CyMoN's Avatar
well looks like he is going to get the rebuild kit from engnbldr and has a guy who will do the bottom end work then he will put the head back on and everything else.
good thing is he has a second turbo motor so he is going to have the work done on it and then pull the one in the runner and swap them, the rings are blown on the second one as well.
Old May 11, 2007 | 04:47 PM
titicaca's Avatar
anybody have a fsm that covers the turbo efi setup and all the specs of the turbo stuff?
Old May 11, 2007 | 08:02 PM
tampabayota's Avatar
where in florida are you
Old May 12, 2007 | 06:52 AM
titicaca's Avatar
ocala, i just picked up an 88 turbo runner and im looking to rebuild the entire engine and possibly upgrade to the ct26 or t3/t4. im looking for any kind of links and info that people may have , pictures ect.
Old May 12, 2007 | 07:33 AM
titicaca's Avatar
heres some pics i only paid $296 the engine actually ran, the guy just wanted to go through it because he planned on building it for his wife. he lost interest.
God's Bounty Hunter
Oct 23, 2015 09:44 AM
RatOmeter
Oct 22, 2015 03:17 PM
ChiefTetlow
Aug 10, 2015 04:19 AM
toofly1999
Jul 25, 2015 07:09 PM
karbin
Jul 5, 2015 11:37 PM
