Turbo???
Old Nov 1, 2008 | 12:35 AM
layedyota's Avatar
ya this motor came turboed it will prolly give me more lienency if i upgraded turbo keep it at14lbs bigger injectors and at least 3 in exaust along with intercooler!!! 22re prolly wasnt made to read forced induction unless upgrading ecm right???? sorry learning on these yotas!!!!!!
Old Nov 1, 2008 | 07:06 AM
400yzturbo's Avatar
In my case I used an actual turbo engine (22re-t) in my swap. The turbo engine had dished pistons and a turbo head. I even rebuilt it before installing it. I should have done arp head studs when i was at it. I think my problem was that under large boost the head bolts would stretch and cause my gaskets to blow. I thought about this after I gave up on the whole 22ret engine. I was sick of replacing head gaskets.
Your turbo engine might hold the 14lbs of boost you are wanting to run, but if you want to try pushing more horsepower Arp head studs and an all copper gasket would be the way to go in order to make sure the head stays down.
I was running a 5peed tranny behind mine and it was cool to see people turn their heads when I would shift and they would hear the blow off from the turbo. With only a toyota 4x4 in sight.
The problem with trying to turbo an engine that wasn't designed for it, is: the compression ratio is higher, the cams are different, the pistons are different, the computers are different as well.
I guess you can turbo a n/a engine, but I think your boost would be limited more so than with a turbo designed engine.
Old Nov 1, 2008 | 08:11 PM
Ty's Avatar
Ty
Originally Posted by layedyota
i go both ways LOL !!!!!
haha that is good lol. I like the mini trucks like that. I love it when i see those kinds of trucks goin down the road and scraping frame and shooting out sparks. I guess i go both ways too lmao.
Old Nov 3, 2008 | 07:14 AM
saitotiktmdog's Avatar
www.steedspeed.com
Best bang for the buck. Those 250 dollar manifolds of ebay work ok. Used one before I upgraded. New manifold builds boost so much faster. Engine is much more responsive. Its $685 but I think its worth it.
Old Nov 4, 2008 | 05:03 PM
  #25
annoyingrob's Avatar
^^ Those Steed Speed BOVs are pimp too.
Old Nov 6, 2008 | 06:56 AM
  #26
Yep they sure are.
TheBFA
Feb 15, 2020 06:55 AM
CPD4runner
9
Nov 5, 2017 06:01 AM
voiddweller
53
Feb 1, 2016 05:46 AM
voiddweller
Sep 28, 2015 11:21 PM
viesail
Sep 21, 2015 06:00 AM
