trimming upper control arm
Old Feb 26, 2010 | 09:48 PM
irvingdizzle's Avatar
This part of the arm is barely rubbing against the tire. Has anyone taken their grinder and removed the part that is circled with success?
Old Feb 26, 2010 | 10:12 PM
peow130's Avatar
...so you'd rather weaken a VERY important piece of your vehicle, instead of just buying a spacer?
Old Feb 26, 2010 | 10:17 PM
OutlawMike's Avatar
Yes, I ground that lip back a bit on my rig. Not an issue to grind it, that material out at the end is not in the critical loading area for the control arm.
Grind away, and wear safety glasses.
Old Feb 26, 2010 | 10:21 PM
peow130's Avatar
i wouldnt grind on a critical piece of my vehicles suspension, especially at the end where the balljoint rests :/
Old Feb 26, 2010 | 10:28 PM
ldivinag's Avatar
some people who run the BJ spacer actually have to trim that area to fit the thing in.
on a side note, maybe the OP's wheels have the wrong backspacing?
Old Feb 26, 2010 | 11:39 PM
desertcamper67's Avatar
You only have rubbing on one side?
If so maybe your spindle/knuckle is bent
Old Feb 27, 2010 | 01:00 AM
milehigheric's Avatar
The lip on the end is actually structural...The torsion of the 90 degree lip helps to stop the whole thing twisting under load. You can modify it if you want, people pie cut UCA's, you just have to put the strength back in when your done.
Old Feb 27, 2010 | 01:57 AM
paynemw's Avatar
Sonoran Steel has shaved upper A-arms... they take stock 3rd gen runner a-arms and cut them and then weld it up... check it out on their website for a reference
Old Feb 27, 2010 | 06:46 AM
yoterr's Avatar
just buy some 3/8's spacers or something, you can buy em at the autoparts store much easier
Old Feb 27, 2010 | 07:23 AM
xfactor203's Avatar
This thread has pictures of an upper control arm cut and welded to clear tires:
https://www.yotatech.com/forums/f116/morph-187544/
1uzRunner
63
Nov 10, 2018 03:58 PM
LotOMiles
Sep 14, 2015 11:45 PM
justdifferentials
Sep 5, 2015 06:52 PM
Ryall
Sep 2, 2015 06:48 AM
kirkrunner
Jul 27, 2015 07:59 PM
