Transmission Code 42
Old Jan 24, 2009 | 12:50 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Gee, it seems I remember typing that once before.....in an IM........lol!
Old Jan 24, 2009 | 01:09 PM
BoostinChick's Avatar
This is to test the actual sensor (that plugs into the trans) not the No. 1 sensor...
My set up is all electronic as well.
Old Jan 24, 2009 | 01:20 PM
If I remember, it was for both. BUT, I could be totally wrong., as I'm 1100 miles away from my FSM's.
Old Jan 24, 2009 | 05:37 PM
scope103's Avatar
I believe that the procedure posted by BoostinChick is for testing the "speed sensor" that goes with the cable driven speedometer. There is a reed switch and magnet up in the panel somewhere, near the speedometer itself. Since it is a passive component, you can test it with an ohmmeter.
But BoostinChick has the all-electronic system (no speedometer cable), and there is no sensor in the dash. Instead, there is a single sensor in the back end of the transfer case. It is held in with a single bolt, and has a three-terminal connector. Internally, it is an integrated hall-effect sensor, so an ohmmeter won't help. To test, you could apply 12v to the correct terminals, and measure the voltage to gnd on the third terminal,
(I've never even tried this; the terminals are difficult to access - I tested it in the other direction, by applying a 12v square wave through a signal generator to the speedometer cable, confirming the speedometer worked, but the sensor didn't. But I'm guessing BoostinChick is not equipped with a signal generator.)
The symptoms described sure sound like mine (which were cured permanently by a new sensor). The trick is that it is an expensive part ($300+ dealership), and I can't imagine a dealer (or anyone else) would let you return an electrical part.
Old Jan 24, 2009 | 07:52 PM
  #25
thook's Avatar
Nevermind...........sorry
Old Jan 24, 2009 | 07:55 PM
  #26
thook's Avatar
Here it is. Procedure for testing the dash with an ohm meter.
http://personal.utulsa.edu/~nathan-b.../6combinat.pdf
Old Jan 25, 2009 | 08:23 AM
  #27
I have that FSM and this is where I am confused...scope says I have no in dash sensor since I have no speedometer cable. I ripped apart the dash yesterday and saw nothing inside the dash that would eve remotely look like a sensor. The only thing I can think of is maybe it's in the gauge cluster?
Old Jan 25, 2009 | 11:53 AM
  #28
thook's Avatar
Guage cluster/combination meter. I said dash, but this is what I mean....at the back of the speedometer.
Old Jan 25, 2009 | 05:48 PM
  #29
Maybe I am just really brain dead:
2. INSPECT SPEED SENSOR
Check that there is continuity between terminals A and B
four times par each revolution of the speedometer shaft.
If operation is not as specified, replace the speedometer.
Does this mean I have to hook up the black/red terminals onto the A and B terminals on the gauge cluster WHILE driving around in order to rotate the speed shaft while in the trans?
Old Jan 25, 2009 | 05:53 PM
  #30
abecedarian's Avatar
no. you should have a lift and rack available so you can do that test in your garage.
this is the FSM you're talking about, right... the one's the mechanics in the service department use?
Old Jan 25, 2009 | 05:54 PM
  #31
Ya ya ya...I understand I have neither (I can dream though!). Just unsure/not crafty on how to test the gauge cluster then.
Old Jan 25, 2009 | 06:09 PM
  #32
so improvise... jack stands... alligator clips (for the wires not the roach)
Old Jan 26, 2009 | 11:51 AM
  #33
thook's Avatar
Did somebody say alligator clips?
(NSFW or kiddies.......)
http://www.youtube.com/watch?v=305vRNoofr8
Old Feb 7, 2009 | 05:46 PM
  #34
So, I just replaced the sensor that's on the outside of the trans. No more CEL but the speedometer/odometer still does not work. Does this mean that my cluster is messed up? Don't really know or have read of anything else it could be, unless I attempt to follow the sensor wire to wherever it connects to?
Old Feb 9, 2009 | 09:43 AM
  #35
Any idears?
Old Feb 9, 2009 | 07:18 PM
  #36
scope103's Avatar
The A340H (4wd pickups) transmission has two speed sensors, named VSS #1 and VSS #2. Both are mounted on the outside of the transmission (strictly speaking, both are on the transfer case), but on opposite sides.
VSS#1 is after the transfer case gears, VSS#2 is before. So VSS#1 is the one used for measuring vehicle speed over the ground (speedometer, cruise, ...), and VSS #2 (I believe) is more for keeping the transmission doing the right thing (because the speed the transmission turns is not directly related to speed over the ground, due to the 2-speed transfer case).
So I'm going to guess you replaced VSS #2, as that sounds like it would have more to do with tranmission codes. If that's the case, you might have had the bad luck to lose #1 at the same time, which took out the speedo (or you might have had some under-truck trauma that damaged the wiring bundle?)
So, first, did you replace the #1 or the #2 sensor?
Old Feb 10, 2009 | 07:04 AM
  #37
From your diagram I replaced the #1 -- it's the one that had the 3 prongs and the gear.
Old Feb 10, 2009 | 10:48 AM
  #38
scope103's Avatar
Given that you lost the code, that suggests the new sensor is good and correctly hooked up at the transmission end. So far so good. It is certainly possible that the speedo itself is bad (I believe it is a tiny stepper motor behind some micro-electronics -- nothing lives forever), but it is more likely that you have a connection problem.
If in your earlier attempts to remedy this you worked on the dash, then it is possible that you loosened a connector somewhere between the transmission and the speedo. Since it looks like the mph signal is getting to the ECM, then the problem is probably closer to the dash.
I've never seen the inside of my dash, so I cannot tell you which connector to try. Also, my (electrical) FSM shows the diagram for the speedo with a drive cable -- not our kind. But I'm 90% sure that the signal wire for the speedo is green/red stripe (because that is what it is at the transmission), so that might help.
Good luck, and let us know what you find!
Old Feb 11, 2009 | 06:51 AM
  #39
When I ripped the dash apart there are 3 connectors that go onto the gauge cluster. That is why I doubt it's that because none of the wires came out of the harness or looked damaged. The only things left I can think of are the gauge cluster itself and possibly a loose connection somewhere where the sensor plugs connect into the firewall and/or harness (as you already mentioned). I wish there was a local yota person near me that I could swap clusters really quick to eliminate this as the possible issue so I can hunt for the connection gremlin.
Old Feb 28, 2009 | 11:55 AM
  #40
ISSUE RESOLVED:
It was my cluster, thankfully I found one on eBay for $30 so I am running close to properly.
