Transmission Code 42
Old Feb 28, 2009 | 12:39 PM
  #41
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Glad you fixed the problem, chicky!!! How do you like the treadwrights?
Old Feb 28, 2009 | 05:54 PM
  #42
BoostinChick's Avatar
Have driven a lot of highway and so far so awesome. The mountain I go to (Blue) is a lot of back roads with slush/ice/snow and they grabbed well. A little road noise but well worth the price and performance. I really hope they do last awhile, if not, I will upgrade to the green diamond OTR's. Definitely will stick with re-treads from now on though, especially from Treadwright.
Old Feb 28, 2009 | 06:23 PM
  #43
Cool....
Old Oct 24, 2012 | 07:27 AM
  #44
milowilli's Avatar
Originally Posted by scope103
The A340H (4wd pickups) transmission has two speed sensors, named VSS #1 and VSS #2. Both are mounted on the outside of the transmission (strictly speaking, both are on the transfer case), but on opposite sides.
VSS#1 is after the transfer case gears, VSS#2 is before. So VSS#1 is the one used for measuring vehicle speed over the ground (speedometer, cruise, ...), and VSS #2 (I believe) is more for keeping the transmission doing the right thing (because the speed the transmission turns is not directly related to speed over the ground, due to the 2-speed transfer case).
So I'm going to guess you replaced VSS #2, as that sounds like it would have more to do with tranmission codes. If that's the case, you might have had the bad luck to lose #1 at the same time, which took out the speedo (or you might have had some under-truck trauma that damaged the wiring bundle?)
So, first, did you replace the #1 or the #2 sensor?
Does a 86 4Runner 22RE have the second speed sensor? I did a inchworm transfer case swap and am having some shifting issues..any help will be appreciated.
Old Oct 24, 2012 | 07:46 AM
  #45
milowilli's Avatar
Does anyone know the purpose of the wire and switch that goes to the bottom of transfer case on this A340H? I did an Inchworm swap using a gear driven transfer case and don't know how to integrate this wire into system. Any help will be appreciated.
smthwsn357
May 1, 2024 07:28 AM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
nonstop
Jul 24, 2015 06:29 PM
mengquis
Jul 13, 2015 10:39 AM
