trans tcase mount
Old Aug 8, 2006 | 04:41 PM
rebult junk's Avatar
trans tcase mount
need a good trans mount for my 88 runner v6 auto 4x4 and maby moter mounts to match does anybody know who sells them
thanks
Old Aug 8, 2006 | 04:53 PM
mt_goat's Avatar
thanks
Toyota dealers and junk yards sell them, also look on ebay and the for sale section here. I'd sell you my old one but it is broken, did your's break too?
Old Aug 8, 2006 | 06:03 PM
ya and looking for stronger mounts and i work in a junk yard thats is where i got my runner
Old Aug 8, 2006 | 06:51 PM
mt_goat's Avatar
The older 4 cyl rear mounts have a big ass bolt running through them to keep them from pulling apart. Why is it everything about the older 4 cyl truck was stronger. They don't make them like they used to. The 95 trucks were the last of the strong frames and transfer cases and the 5VZFE was the last of the good engines.
Old Aug 10, 2006 | 03:12 AM
so nobody has had moter mounts or tranny mount problems
Old Aug 10, 2006 | 06:23 AM
snap-on's Avatar
in a word
nope. not hear and ive bashed my truck fairly hard.
Old Aug 10, 2006 | 07:53 AM
mt_goat's Avatar
Most of the guys having problems with motor mounts are running duel t-cases and the very low gearing breaks them. A lot of them use chains to limit the amount of stretch the rubber will have to take. Here's a little info on that: http://www.4crawler.com/4x4/CheapTri...torMount.shtml
Some of the Taco guys are having problems breaking the mounts and the perch that is welded to the frame. Again seems to just be guys running duel t-cases.
Old Aug 10, 2006 | 10:10 AM
Snorkeldepth's Avatar
I changed my motor mounts when I put the new engine in after 235K miles. The old mounts were noticeably lower than the new ones. (I didn't measure them.) The old ones looked just a bit crooked too, like the rubber had deformed over the years. I didn't replace them because I had a problem, only because I didn't want to have a problem in the future.
Old Aug 10, 2006 | 11:11 AM
mt_goat's Avatar
Yeah I just put in new motor mounts too, just because the engine was out and didn't want a problem later. My old ones are smashed down about a 1/4 inch compared to the new ones. I also chained mine because I'm adding duel cases. http://community.webshots.com/photo/...42310107EbJpVn
Old Aug 10, 2006 | 12:42 PM
thanks where did yall get them or do i just get oem toyota mounts
and no duel t case just age i guss i have got a lot of movement in the moter
and have notest the movment increse over the last 6 months so mutch movment i think the moter and trany tcase are just sitting there i dont think it is held down at all just floting around in there and that is not good.
Old Aug 10, 2006 | 01:02 PM
Mine are OEM. I replaced the motor mounts as well as the T case mount. TRDParts4U has great prices if you decide to go OEM.
Old Aug 10, 2006 | 02:27 PM
mt_goat's Avatar
Yeah mine are OEM too, they came with my 3.4 swap kit from ORS. There are some heavy duty aftermarket mounts made for hardcore offroading but a lot of vibration can be felt with them and many who put them on daily drivers end up taking them off. I hear they are fine for trail only rigs.
Old Aug 10, 2006 | 02:55 PM
Back in the Baja Bug days in high school I had a buddy that put a solid transmission mount on his bug. Definitely not the thing for a DD if I recall correctly. There was a lot of vibration and it was really loud too.
crammit442
7
Nov 29, 2017 12:30 PM
Chumlee780
Nov 13, 2015 03:18 PM
Pedalpwr27
Aug 13, 2015 06:37 AM
yourrealdad
Jul 29, 2015 11:08 AM
keithporter83
Jul 24, 2015 07:37 AM
