Tramsmisson problems
92 4Runner 3.0 auto 4wd. I drove 20 miles to school on the interstate with no problems but when I got out of class my transmission was having problems. I can put it in drive or reverse and it acts like it's in neutral and just revs up but if I put it in 4lo it'll drive. What could cause these issues?
Yea runs and idles fine. No check engine light just checked to see if any codes were stored. I seen someone mentioned the tps could cause trans issues so just trying to cross off the easy stuff before I pull the trans
Check for transmission codes. http://personal.utulsa.edu/~nathan-b...31diagnosi.pdf
(I assume you have an A340H; it's listed on the door pillar.)
theking11863
Mar 19, 2016 09:36 PM
sounds like you are on the right track.
