Tramsmisson problems
Old Feb 25, 2015 | 09:21 AM
Corey Barlow's Avatar
92 4Runner 3.0 auto 4wd. I drove 20 miles to school on the interstate with no problems but when I got out of class my transmission was having problems. I can put it in drive or reverse and it acts like it's in neutral and just revs up but if I put it in 4lo it'll drive. What could cause these issues?
Old Feb 28, 2015 | 08:45 AM
Anybody?
Old Feb 28, 2015 | 12:55 PM
I checked it today and now it won't drive in any gear 2wd or 4wd. Does that sound like a bad torque converter?
Old Feb 28, 2015 | 01:36 PM
Schnayke's Avatar
did you check the fluid level?
Also did you check the linkage?
Old Feb 28, 2015 | 01:48 PM
Fluid level is good. It's shifts in gear and try's to go, I can feel the truck start moving forward so i assume the linkage is fine I'll check to make sure though
Old Feb 28, 2015 | 01:49 PM
I pulled the codes and it had code 41 stored so I'm gonna check the tps and see if it's in spec
Old Feb 28, 2015 | 02:47 PM
Schnayke's Avatar
Does the engine rev fine, and idle correct? Might just be another issue, was the check engine light on before the problem?
Old Feb 28, 2015 | 02:49 PM
Yea runs and idles fine. No check engine light just checked to see if any codes were stored. I seen someone mentioned the tps could cause trans issues so just trying to cross off the easy stuff before I pull the trans
Old Feb 28, 2015 | 02:55 PM
Schnayke's Avatar
Yeah, my mechanic always says fix the problems you know you have first. sounds like you are on the right track.
Old Feb 28, 2015 | 03:44 PM
scope103's Avatar
Check for transmission codes. http://personal.utulsa.edu/~nathan-b...31diagnosi.pdf
(I assume you have an A340H; it's listed on the door pillar.)
Old Feb 28, 2015 | 04:03 PM
I do have the a340h. Thanks for the link I'll try that tomorrow
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
