Towing Capacity
Old Sep 5, 2011 | 02:56 PM
yodaLJ's Avatar
Towing Capacity
I have searched and have found no definitive answer to what the manufacturers towing ratings are on these trucks.
I have a 1991 Toyota ext cab 22RE 5spd truck, and I would like to tow a 5,000lb landscape trailer. I no I will have to wire the truck for trailer brakes, but is the truck rated for this? The trailer will roughly weigh 3,100lbs including the weight of the trailer. I want to be legal and everything, but cannot find out if the truck is rated for it. I know it will not be a power house and it won't be able to do 70 on the highway, but can it tow the trailer legally?
Old Sep 5, 2011 | 05:05 PM
ProjectMcFly's Avatar
Per my owners manual, the towing limit was 3,500 lbs. I don't know what the limiting factor of the truck is (brakes, frame intergrity, HP).
Old Sep 5, 2011 | 05:09 PM
TNRabbit's Avatar
That's WAY too much.
Old Sep 5, 2011 | 05:29 PM
yodaLJ's Avatar
What is way to much? 3500lbs?
Old Sep 5, 2011 | 06:00 PM
rhill's Avatar
you'd like to tow a 5000lb trailer that weighs 3100lbs...and you're asking if 3500lbs is too much? these numbers are confusing.
Old Sep 5, 2011 | 06:20 PM
yodaLJ's Avatar
trailer GVW of 5000lbs, but actual weight is 3100lb. Meaning that the trailer is rated to carry up to 5000lb including the weight of the trailer and payload. With my payload the weight of the trailer is going to weigh 3100lb with the trailer inlcuded.
I didn't no it was rated at 3500lbs until ProjectMcFly said so.
TNRabbit said thats WAY too much, and I am trying to figure out if he ment 3100lbs is too much.
Sorry for the confusion
Old Sep 5, 2011 | 06:30 PM
94toy22re's Avatar
is it 4x4? i have pulled more then that with my 22re the worst part is stopping as along as you take your time it should be no problem. and make sure you have actual hitch the stock bumper is not good for anything over 1000lbs
Old Sep 5, 2011 | 06:34 PM
yodaLJ's Avatar
no i will have a full reciever style hitch, and wiring it for trailer brakes also.
justdifferentials
14
Jun 11, 2017 08:36 PM
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
toyhaulert100
Sep 24, 2015 07:55 PM
