Total Front Suspension Refresh
hello, first post here and I'm sure glad I found this site BBS. A friend recently gave me his 95 4Runner with 183K on the clock, known issues included needing a new windshield, new tail gate and front brakes. Lots of rust around the truck too, but it was only $800. After driving it from Maine down to Boston, I knew it absolutely needed brakes...metal on metal. Note that I know nothing about 4Runners at this point.
So the first thing I do (foolishly) is have a windshield installed and get a tail gate out of a local junk yard. I'm now $1300 into the truck, but since there's a wholesale auto part distributor on the floor below where I work, I get parts very cheap and think I'll have a decent truck for $1500 or so.
Getting it up on jackstands 2 weeks ago armed with my new Haynes manual, I find it fairly easy to pull apart. BUT, the more I dismantle and inspect, the more I find that every single component in the front suspension is absolute toast. the lower A-arms have more rust (empty space) than metal. The uppers are just bad enough that they really ought to be replaced now that everything is apart. the calipers are frozen. the rotors as expected are junk. the bearings are good on one side, bad on the other, anti-roll bar links are dangling having pulled through the rusted out A-arms long ago, shocks are bad and 2 boots are torn on the axles.
At this point my friend gives me back the $800, but I've $500 into it so I (foolishly) decide to soldier on.
So now I'm $1200 into the truck as I write this with new:
windshield
tailgate
shocks
axles
complete brakes
bearings
hub hardware (new studs from Toyota, etc.)
Upper and lower used A-arms out of California
Hubs have been bead blasted and are awaiting POR15 and when I get the upper arms from CA, every surface I can paint, I will.
Some bad news along the way. One bolt holding the ball joint on snapped off in the knuckle. One of the surface plates/washers on the lower A-arms was missing. I torched out the bushing and have one on order from Toyota.
Questions:
Upper A-arms. I've yet to find a good procedure for replacing these. Anyone have a link or advice on how to do it?
Is is OK to paint the holes for the cone washers with POR or should I mask them out?
are there any bare threaded surfaces that should NOT get anti-seize?
windshield
tailgate
shocks
axles
complete brakes
bearings
Questions:
Crank the T-bars down before you try replacing the upper a-arms. Other wise, once you undo the 3 bolts holding them, they will twist where they sit and you wont be able to remove them. The T-bars can stay in place, but the pressure MUST be relieved.
congrats on your new to you 2nd gen.
I wanted to just mention that many times you can upgrade the parts you are replacing for about the same money or just a little more-and it sounds like you are going to be doing some serious wrenching.
Just for example when you said the calipers were froze up I thought back to when I owned a 2nd gen (also a 95) and always cursed the front brakes as I would eat through rotors routinely. There are a number of brake upgrades out there, I think using Tundra calipers is one of them and just wanted you to "think big" from the beginning and not limit yourself to just replacing factory parts with the same part numbers.
It sounds like rust is just killing the earlier Runners out east. But what a buddy you have there!
good idea.....for THIRD GENS.
He has a second gen, so tundra brakes are not even an option.
Cranking down the t-bars means to loosen the large long bolt on the end of the torsion bar (under the cabin) until all the pressure is off the torsion bars.
thanks for the help guys, much appreciated!
Ron, I'd like to go all out on this truck, and may some day, but for now I'm getting everything a local garage would just to get it going, and being a little cash poor these days, my hope is to just get it on the road as cheaply as possible, weld up all the holes in the body in February (I hope CA yards will cut sheetmetal to order) and then reassess it's future. the good part is everything that should be blasted and POR15'd and anti-seized is so anytime I need to take it apart, should be easy.
yes, I do have good friends!
the only thing that would hold me up from going nuts on the truck is that there seems to be a slight lifter noise in the motor, not metallic, but more like a flutter. Will have to thoroughly check that out. Before tearing apart the front, I changed the oil with 5/30 and put in a pint of Marvel. We'll see how it runs next weekend if it's off the stands.
Thanks DC on the cranking TB concept. Glad I bought a gallon of PB Blaster!
Front suspension - NORMAL wear items are ball joints & idler arm on these trucks. Look at replacing those "while you're down there." Also have a look at your tie rod ends, & other parts too.
i agree with the last few posters 100%....
also www.toyotafiberglass.com sells sheet metal repair kits for around the rear wheel wells. they also sell fiberglass front fenders, i run their stuff and it's top notch.
Mine doesn't have frame rot, but the underside of the cab has rot the length of the rockers. Seems repairable, and in my case it isn't a DD. 2nd gen yotas are hard to come by where I'm at, and I'm gonna get this truck back on the road. He paid $800, I paid nothing.
Oh, and thanks for the link. I think those rockers might work for me.
the frame is surprisingly very good. the factory black paint/coating on the frame is intact for the most part with little minor rust. I'll replace the front fenders and bumpers, don't need the running boards and will have to weld in new rear quarters (or some portion of the sheetmetal) as well as rear bottom sheetmetal at the rear doors. If a West Coast or southern yard will cut the sheetmetal for me, I should be able to get it all in over a weekend.
if the engine checks out, I could see painting it in June or so. Given straight panels, I should be able to get away with just hitting it with 400/220, a cheap high build primer, quick sand and then a single stage coat, color TBD.
Coed, the ball joints that came with the lower arms seem to be good (very stiff) and hoping the uppers coming will as well. it has some new components in the front, I believe a new pitman arm. Will have to check on the idler arm, thanks.
At the end of the day, I could easily put $4K into it including a new motor, $2K without. But I'll have a really great truck that is virtually brand new that will last forever. I'm not a big fan of new cars and even wish this had a big old straight six with some torque on hand.
Will post some pics of the build. Nasty weather here though and I'm working outside, so hoping it will clear up as soon as I've got all my parts in.
Thanks for all the support! it's nice to know I'm not alone in doing all this.
Keep in mind that the frames on these trucks often rust from the inside out, where you can't see it. Might be a good idea to tap on the frame with a wrench or hammer and listen for any non-solid spots. That could be a problem.
wow you have got a lot of work to do it sounds like -what a project truck
thanks deathcougar I did not realize the Tundra caliper upgrade for front brakes were only for 3rd gens.-thought I had read of some 2nd gens using them also.
Ron, as long as I can get it drivable, I'm OK for the long haul.
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
