Torsion bar trouble
Old Aug 23, 2020 | 03:01 PM
BabyYota94's Avatar
Torsion bar trouble
So I'm about to under take the task of installing a lift kit, I was told by a shop who looked it over that I need torsion bar rear mounts, however I have absolutely no idea what part that actually is, my Haynes manual says anchor arm but I'm not sure if that's right, if anyone can help me out it would be much appreciated!
Old Aug 24, 2020 | 09:06 AM
Dr Phat's Avatar
Im not sure what your question is, what type of lift are you putting in? They’re saying your truck does not have torsion bar anchors/adjusters?
Old Aug 24, 2020 | 09:11 AM
BabyYota94's Avatar
I have a 94 4runner and I'm trying to put in a complete 2" ome lift including torsion bars, the shop I brought it too said I need to replace rear torsion bar mounts, the part that sticks out of the frame, all I'm asking is if it's an actual part I can replace or if it's part of the frame. The pics I included were from a forum post showing what I'm talking about. thanks in advance
Old Aug 24, 2020 | 10:05 AM
Dr Phat's Avatar
Are the mounts that are welded to the frame rusty or cracked? Or are the adjusters just rusty and seized? You need to figure out exactly what they mean.
Old Aug 25, 2020 | 05:50 AM
swampedout's Avatar
5 Year Member
Take pics down there.
i want to know what you think of this kit, so lets get it installed!
Old Aug 25, 2020 | 02:23 PM
BabyYota94's Avatar
This is what I'm talking about, is this a built in piece of the frame or is a part that can be replaced and if so what is the part number
Old Aug 25, 2020 | 03:48 PM
Co_94_PU's Avatar
Frame...
They are welded in, some or all of these brackets were order able once upon a time.
The brackets look better than the frame from way over here on the other side of the internet. Take a wire wheel to them and see what you really have under all that mess.
Are you sure they weren't talking about the arms on the ends of the torsion rods, you can't see these in the pictures and they'll have to come out to get eyes on them anyways.
These brackets are pretty basic, could knock them out in a day (mostly) with a good press. The arms are a whole other story those are cast.
Old Aug 25, 2020 | 04:09 PM
swampedout's Avatar
5 Year Member
Yup. the area you circled is a weld.
Im assuming the shops concern is rust, but was there anything specific they said about cracks in the mount?
Old Aug 25, 2020 | 04:15 PM
Dr Phat's Avatar
So your hardware is most likely hammered from cancer, but your brackets look highly suspect as well. How is the other bracket? Link for new hardware below.
https://www.lceperformance.com/Torsi...iABEgLszfD_BwE
Old Aug 25, 2020 | 04:58 PM
BabyYota94's Avatar
have new hardware from my local Toyota dealership ready to go, the bracket I believe is what I'm trying to find a replacement for, the other side isn't as bad isn't impressive by any means
Old Aug 25, 2020 | 05:02 PM
BabyYota94's Avatar
They just said that they looked for the part and couldnt find it
Old Aug 25, 2020 | 05:05 PM
BabyYota94's Avatar
Originally Posted by Co_94_PU
Frame...
ok I'll wire wheel away this weekend, are the arms your talking about anchor arms cuz I found a part for that, the brackets if needed to be replaced where should I take them to be remade?
Old Aug 26, 2020 | 12:49 PM
MaK92-4RnR's Avatar
Cut that ˟˟˟˟ out and SAS it.
Old Aug 26, 2020 | 03:52 PM
Mr. Z.'s Avatar
Have you tried to finding parts using an overseas vendor?
I've had great luck with the following mob...the delivery was fast as well.
https://partsouq.com
Cheers
Old Aug 26, 2020 | 04:59 PM
akwheeler's Avatar
Not seeing any dollar amounts on your estimate I am just guessing, but I'd say it'll cost you almost as much as a solid axle swap.
Old Aug 27, 2020 | 07:03 PM
swampedout's Avatar
5 Year Member
That does seem like it will be a pricey repair bill but the only thing I see is the rust issues and the spindle replacement.
everything else is more or less routine wrenching.
if you have the resources to do sas, you can fix what you already have, for less. Just my 2 cents
Old Aug 27, 2020 | 07:05 PM
swampedout's Avatar
5 Year Member
Find someone who did an sas nearby, theyre bound to sell you all their "ifs junk" for pocket change.
I got a whole front end with 150k miles on it for 100$
rbradshaw96
Nov 25, 2012 05:45 AM
884ruiner
Feb 9, 2010 05:44 AM
mrtrd103
Jan 27, 2009 01:54 PM
yota yota yota
Aug 14, 2007 09:28 AM
Kiff
Jun 6, 2007 05:36 AM
