Torsion bar crank and rear lift question
Old Jun 25, 2009 | 10:25 PM
digital's Avatar
94 Toyota Pickup 4x4
I will be installing 32'' BFG KM2 M/T's.
After adjusting the torsion bars, I measured exactly 14.5" from the top of rim to the fender. With the torsion bars at this height do I need to worry about excessive CV joint wear or anything else?
My 2nd question is what should I do as far as adjusting the the height of the rear of the truck? Seems likes shackles may be the way to go? How much more height should I go in the rear, 2"?
Old Jun 25, 2009 | 10:32 PM
Tubbyfatty's Avatar
You could get some ball joint spacers so you dont have to crank them bars.
Cant you fit like 33s stock? I know you can on 4runners but idk about trucks.
Old Jun 26, 2009 | 01:52 AM
abecedarian's Avatar
31" was about all I could put on my 88 with a 3.75" backspaced wheels and not have them rub the fender at full lock turns. I understand this is a 94 we're talking about here and there was a 31" option so take what I said for what it's worth.
Adjusting the t-bars for 1.5" lift puts the CV's at the same approximate angle as no t-bar adjustment with BJ spacers so CV life should be the same with either. ADD equipped vehicles are more prone to issues with either since the CV turns all the time. Cranking the bars will stiffen the ride though. Considering that, if 32's will rub without any lift, BJ spacers won't eliminate that problem, nor will t-bar cranks, but cranking the bars will stiffen the suspension and make it more difficult to bottom out the suspension.
However, if I were only looking for the ability to install larger tires and didn't have sufficient body clearance for those tires, I'd opt for a body lift kit, probably in the 1" range. 1" would suffice since 31's can be installed and a 32" tire, although 1" taller, is only around 1/2" larger in diameter.
Old Jun 26, 2009 | 02:41 PM
digital's Avatar
Thanks for the info, very helpful post.
What do you recommend I do for the rear of the truck? i.e. shackles new leafs? what size do I need, etc.?
Thanks bud.
Old Jun 26, 2009 | 04:14 PM
crafthorse's Avatar
I cranked my TBars, and added Add-A-Leafs to the rear, I have enough room for 33s under mine although I have 32s.
Old Jun 26, 2009 | 04:30 PM
digital's Avatar
Can you post a link to the add-a-leafs you used? what year is your rig?
Also, I measure 14.5" from the top of the wheel to the fender, will I have any issues with that?
thanks
Old Jun 26, 2009 | 05:14 PM
crafthorse's Avatar
I got mine from NAPA. The store I got them from had a lot of no typical stuff. I dont know if the other stores have them.
You should not have any issues.
Old Jun 29, 2009 | 11:54 AM
lngrnge's Avatar
Anybody try the 26mm torsion bars from Downey?
Old Jun 29, 2009 | 12:18 PM
affmondo22's Avatar
add a leafs will also stiffen your rear spring pack, causing your ride quality to get worse. I think shackles would be a better option. Wabfab sells them, thats where i got mine.
Old Jun 29, 2009 | 12:54 PM
Jay351's Avatar
Stiffer front torsion bars are never recomended unless you have a heavy (ARB or WARN) front bumper with a winch. If not, oem is perfect.
For the rear, see if your overloads are resting on the rest of the leafs. If so, they are shot (SUPER common), so get new leafs for a nice ride, or be cheap and get AAL's (they will ruin the leaf pack over time) or shackles (for every 2" longer you get 1" lift).
tire clearance depends on your rims the most. If you keep the stock or rims that have the same stock backspacing (4.75") then you can run up to 33x10.50" tires stock. The farther the tire pokes out, the more rubbing will be an issue. I have almost 5" of lift and still rub my tires..
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
