Thinking about a swap need help!!
Old May 26, 2016 | 05:48 PM
jessie301's Avatar
hey there guys i have a 1989 toyota pickup 4wd 5speed with the 22re thinking of doing a swap was either thinking a hilux turbo diesel swap or a 7mgte or possibly even a 2jz vvti swap but am just kinda curious as to what one would be easier as this is my first ever swap and have little experience and minimal help have been doing some research but still just kinda need that extra little help to get placed in the right direction with getting this swap underway any and all help and opinions welcomed thanks in advance
Old May 26, 2016 | 09:19 PM
punks_is_4x4's Avatar
Well first off do u have access to any of the engines u listed
Old May 26, 2016 | 11:00 PM
Robert m's Avatar
https://www.yotatech.com/forums/f159/ Start reading...
Old May 26, 2016 | 11:35 PM
wyoming9's Avatar
It really depends on what your definition of easy .
Just what area are your best skills in.
Some the mechanical work is the hard part just getting the old engine out .
Some look at the merging of wiring harnesses and just decide to not even start .
The bottom line is what is the end result desired
Old May 27, 2016 | 03:47 AM
jessie301's Avatar
yes there is plenty online that are available to buy!!!!
Old May 27, 2016 | 03:54 AM
jessie301's Avatar
definition as to easy would be not having to chop the frame in half and weld it back i can weld and know how to turn wrenches and i have the motor pulled already just needed kinda a guide to which might be the most simple if that makes sense i dont want to really have to do anything crazy i have access to alot of tools and equipment as my cousin is a mechanic but hes got his own projects to do i just didnt know if maybe any of these i could keep the stock transmission or keep anything that i have on my current 22re setup hell i might consider doing a 22re turbo i just wanted something different than ive ever seen in my state you know something that just shocks and awes everyone
Old May 27, 2016 | 05:30 AM
Innocent Fool's Avatar
If you're looking to swap out the 22RE for something I'd look at swapping in a 3RZ-FE 4cyl
Should be some info about this in the Engine Swap Section.
Old May 27, 2016 | 07:45 AM
Flash319's Avatar
Easiest. Still a major swap. There is nothing easier then the 3rz to replace a 22re except maybe a carbed 350chev driveline.......but wtf.
Even easier, by a Taco with a 3rz in it. Thats my nxt move....
Old May 28, 2016 | 12:59 AM
wyoming9's Avatar
Know the7M engine is 6" longer then the 22R series engine.
I was going to do that swap have all the parts but I just like the 3.4 swap better.
All kinds of support compared to all most any other swap.
Old May 28, 2016 | 03:29 AM
az1320's Avatar
if you want a project that you will be able to finish this year and don't have to re-engineer the wiring or the suspension of the truck I would look up lcengineering.com and look into some sick power from a 22re and then a sas with lockers and 5.29 gears. truck would still be light and no re-engineering the wiring harness. as far as wow factors go pull some f150s and 1500s out of the mud and you would be set.
Old May 28, 2016 | 07:09 AM
donomite49's Avatar
3rz if you want 4 cyl, 5vz or 2jzgte if you want 6 cyl, Lexus or ls chevy if you want v8.
I'm with Wyoming, I like my 3.4. I'm happy with my choice.
You make the decision for your truck, all depends on what you want and can spend.
Old May 29, 2016 | 06:11 AM
wyoming9's Avatar
No matter just what swap you plan to do they each have there own unique set of problems .
Maybe problem is not the correct word perhaps challenges would be better suited
Old Jun 7, 2016 | 10:18 PM
TransAmBandit's Avatar
7MGTE wouldn't be as difficult as most parts can be found second hand for cheap and people basically give those motors away these days. 2J VVTI wouldn't be than much harder as swap brackets for a Celica or Cressida can work. But mating the JZ with the proper bellhousing would cost a bit more than the one for a M series engine.
I did a 5MGE swap into my 87 Xtracab 4x4 and I thought it was pretty easy. The wiring is almost the exact same thing as the 7MGE/GTE. As you're matching the same functions. Merging the harnesses aren't a big deal if you can read a diagram and there were many par write ups on these swaps. I used most of them for reference and wired my truck myself. But I had the factory electrical diagram books for the truck and the book for the Creasida the motor came out of. My build thread is in the Build up section if you're interested.
SueLu
Feb 24, 2016 08:23 PM
alva22re
Feb 20, 2016 04:21 PM
goofybud16
Feb 6, 2016 01:29 PM
Damiandominguez
Jan 28, 2016 01:58 AM
