Testing rear window power switch (up/down)
Old May 8, 2016 | 06:14 PM
mattyboi's Avatar
My rear window works but the previous owner has jimmy rigged it up in a way that requires plugging the wire into the cigarette lighter and if I want the window to go the other way then I have to unplug it and switch the wires around lol Works but it's getting annoying so I'm going to try and fix it. Here it is . Can't really see it in the pic but the cigarette adapter is sorta broken and has a paper clip stuffed inside it lol
I followed the instructions in the FSM, and one of the test has me checking the continuity in the up/down switch in the center console for the rear window. ( http://web.archive.org/web/201008021...e/backdoor.pdf page 3)
When I test for continuity (while the switch is pressed up or down) my multi meter beeps but it shows 0 Ohms. Do I need a new switch or is it all good?
Old May 8, 2016 | 06:21 PM
millball's Avatar
The console switch does not directly apply 12v power to the window motor.
It acts on a relay/relays in the drivers rear quarter area.
You need an electrical wireing diagram for your year/ model in order to make much headway..
The multiple interlocks and safetys built into the rear window system make troubleshooting a little less than straightforward.
Old May 9, 2016 | 04:48 PM
osv's Avatar
osv
i've been thru the rear window cr*p on my '86 4runner, inside and out, including replacing all of the relays on the circuit board... it's still not 100%... see if this helps: http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old May 9, 2016 | 09:31 PM
Terrys87's Avatar
I had a lot of problems with rear windows and here is what works for me>>>>https://www.yotatech.com/forums/f199...l#post51722787 on post 185&186.
Old May 13, 2016 | 12:57 PM
RAD4Runner's Avatar
Since you motor works, I strongly recommend you tear out all the Jerry-rig parts, and restore wiring to stock. Pls see my thread for stock schematic and suggested test points.
Also inspect and test your wiring, especially the flex harness between door and body.
Report back and we'll talk.
Old May 14, 2016 | 01:56 AM
wyoming9's Avatar
Red face
Hello did you all miss the fact when the OP tested the switch it did ring out.
0 ohms means no resistance if the meter did not beep the circuit is open
Tells me the switch works .
OP do you have any idea just where those wires go attached to the power socket ??
Does the window work from the key switch in the hatch ??
These circuits are so simple compared to what I need to trouble shoot at work.
Why people butcher the stock wiring is beyond me.
mtnkid85
3.4 Swaps
13
Jan 26, 2026 04:58 AM
steele34
Apr 6, 2016 08:05 PM
Vernsyota
Mar 7, 2016 04:41 PM
TransAmBandit
Mar 2, 2016 11:16 PM
sandfantom
Feb 17, 2016 05:11 AM
