Temp Fix for a EFI Fuse Blowing, tell me if this is a good idea
Old Jul 6, 2009 | 09:15 AM
simpsons721's Avatar
Red face Temp Fix for a EFI Fuse Blowing, tell me if this is a good idea
my car is 45 min away from my house
im gonna look for the short but if that doesnt work if i can get my car started doing a temp fix, is this a good idea
I was reading up on an efi fuse blowing and people said sometimes using a stronger fuse will at least get it started
also removing the efi relay
is there anyway to bypass the fuse to make it run
also does anyone have the link for the wiriing diagram to the efi fuse
thanks
Old Jul 6, 2009 | 10:04 AM
TNRabbit's Avatar
DO NOT BYPASS THE FUSE! Unless you want to burn your truck up.
Blowing the EFI fuse is common when the O2 sensor wire has burned on the exhaust or is shorting out some other way. Check that first. Them check the FSM:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Jul 6, 2009 | 10:40 AM
bugs1961's Avatar
Yea, what TNRabbit said. NEVER bypass a blown fuse. It only blows when there is too much current in the circuit due to an overload. The designated size fuse is designed to let all the necessary current pass but blow before the wiring is damaged or starts a fire.
Fuses don't just blow for no reason. You had to have excessive current in the circuit when it blew and the problem has to be found and fixed. I'd tow it rather than bypass the fuse. Good luck,
Bugs
Old Jul 6, 2009 | 11:19 AM
gametom's Avatar
before i say this i want it to be heard i would never do this. someone told me once jumper the fuse with a wire and look for smoke that's where the short is.
Old Jul 6, 2009 | 11:28 AM
swapped89's Avatar
check it out
https://www.yotatech.com/forums/f131...ze-box-183231/
also if you search efi* fuze* there are lots of threads on this
Old Jul 6, 2009 | 02:09 PM
Justinlhc's Avatar
lol yeah bad idea.
I would search hi and low for the problem before I tried anything crazy like bypassing the fuse.
Old Jul 6, 2009 | 02:51 PM
Tragic Drive's Avatar
Old Jul 6, 2009 | 03:38 PM
scuba's Avatar
You only have to put the **asterisk** for 3 letter words, But B for effort buddy
Old Jul 6, 2009 | 04:22 PM
abecedarian's Avatar
thanks for helping solve the problem buddy.
Old Jan 6, 2010 | 06:44 PM
Blue_petersen77's Avatar
Yeah, I had the same problem. Check the O2 sensor, if it's touching the exaust pull it off and keep it tied back and off of it. That completely solve the problem for me. The easiest fix ever... Just move a wire =)
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Jul 7, 2015 04:05 AM
Jnkml
Jul 6, 2015 01:20 PM
ptb12
Jul 5, 2015 01:49 PM
