Temp Fix for a EFI Fuse Blowing, tell me if this is a good idea
my car is 45 min away from my house
im gonna look for the short but if that doesnt work if i can get my car started doing a temp fix, is this a good idea I was reading up on an efi fuse blowing and people said sometimes using a stronger fuse will at least get it started also removing the efi relay is there anyway to bypass the fuse to make it run also does anyone have the link for the wiriing diagram to the efi fuse thanks |
DO NOT BYPASS THE FUSE! Unless you want to burn your truck up.
Blowing the EFI fuse is common when the O2 sensor wire has burned on the exhaust or is shorting out some other way. Check that first. Them check the FSM: http://personal.utulsa.edu/~nathan-buchanan/93fsm/ |
Yea, what TNRabbit said. NEVER bypass a blown fuse. It only blows when there is too much current in the circuit due to an overload. The designated size fuse is designed to let all the necessary current pass but blow before the wiring is damaged or starts a fire.
Fuses don't just blow for no reason. You had to have excessive current in the circuit when it blew and the problem has to be found and fixed. I'd tow it rather than bypass the fuse. Good luck, Bugs |
before i say this i want it to be heard i would never do this. someone told me once jumper the fuse with a wire and look for smoke that's where the short is.
check it out
https://www.yotatech.com/forums/f131...ze-box-183231/ also if you search efi* fuze* there are lots of threads on this |
Originally Posted by gametom
(Post 51177196)
lol yeah bad idea. :fire2: I would search hi and low for the problem before I tried anything crazy like bypassing the fuse. |
Originally Posted by swapped89
(Post 51177204)
also if you search efi* fuze* there are lots of threads on this You only have to put the **asterisk** for 3 letter words, But B for effort buddy :bigok: :dj: |
Originally Posted by scuba
(Post 51177399)
:dj: :stir: |
Yeah, I had the same problem. Check the O2 sensor, if it's touching the exaust pull it off and keep it tied back and off of it. That completely solve the problem for me. The easiest fix ever... Just move a wire =)
