Suspension lift question
Old Mar 11, 2008 | 09:34 PM
mr_schuster's Avatar
I am looking at different suspension lift kits and have noticed that all of them use blocks between the rear axle and the spring. Is this necessary or a sign of a cheap suspension lift. My goal is to achieve max height with maximum wheel travel. Doesn't the lifting block eliminate spring travel. Does anyone know of a good 4" lift that uses springs in the rear? Whats your opinion?
Old Mar 11, 2008 | 09:48 PM
Dare44's Avatar
deaver springs, or chevy 63" springs
Old Mar 11, 2008 | 09:56 PM
Matt16's Avatar
You need to read about axle wrap, wheel hop and the associated damage to drivetrain components. Lift blocks are a back idea. A lift block only lifts you farther off the ground, it does not increase travel.
A better option are longer shackles or lift springs.
Old Mar 12, 2008 | 12:25 AM
ovrrdrive's Avatar
Just buy whatever kit you are looking at and use the front parts of it and just throw the blocks away. Then go to Trail Gear and buy a rear kit.
A good rear kit will run you about $600 more. That's why most of the lift kits just throw in a set of blocks for the rear.
I have a lift spring and a block in mine and it does wrap up a little, but it's more than tolerable for the wheeling I do.
Old Mar 12, 2008 | 12:40 AM
4x4YOTA's Avatar
I did an add-a-leaf and shackle in my old pick up to get about 4" and was happy with it
Old Mar 12, 2008 | 05:03 AM
dirtoyboy's Avatar
check out marlin, sky or allpro
all utilize longer than stock springs and mounting locations so welding is required. Any (4"+) lift that uses stock spring mounting locations will ride and flex like a brick and most likely has blocks....
I dont recommend blocks
If you are cheap...look into chevy 63" in the rear and rears up front
Old Mar 13, 2008 | 05:29 AM
OK. So Im broke and cant afford the SAS or the AllPro rear lift, so in the mean time here is the plan to get my truck in the air. I am going to buy a 4" lift ( Yeah the one with the rear blocks) any suggestions ???
Old Mar 13, 2008 | 06:23 AM
dirtoyboy's Avatar
Procrap, Skycrapper....it dont matter...they are all pretty much the same. CHEAP...you get what you pay for
Old Mar 13, 2008 | 07:42 AM
CanTheWhales's Avatar
Search for 63" Chevy springs in rear... it will give you a flexible, softer and 3-4" taller ride. Besides, ride height is always adjustable through shackle length anyways (to an extent). Pirate has a FAQ on this topic....<LINK>
Old Mar 13, 2008 | 07:44 AM
redvette's Avatar
Downey's rear spring flex decently for stock locations. They are priced well too. $200 for a pair.
Old Mar 13, 2008 | 08:14 AM
dirtoyboy's Avatar
I think hes trying to avoid any extra fab work.....
Old Mar 13, 2008 | 08:15 AM
dirtoyboy's Avatar
Yes, they do flex well for what they are ....I have run many pairs of them (and so have quite a few of my friends)......every one I have seen has bent...
Old Mar 14, 2008 | 12:37 AM
ovrrdrive's Avatar
Skyjacker and Superlift are the only two bracket lifts worth getting because they both use full length drop brackets. A Procomp Stage 2 has some nice re-enforcing bars with it but the drops are still tabs and it costs $300 more than a Superlift or $500 more than a Rough Country (same lift as Superlift with different coatings).
Old Mar 14, 2008 | 06:54 AM
yoterdrvr's Avatar
Marlin crawler has springs for a four inch lift
Old Mar 14, 2008 | 07:24 AM
the85yota'08's Avatar
there are soo many options you have you could pay a little extra i mean a lot extra and go for the marlin crawler lift or you can do what a lot of yota wheelers do and swap those springs for those of a 88-98 1/2 ton chevy im doing more research on the spring swap
Old Mar 14, 2008 | 07:29 AM
Toyvana's Avatar
Dang, sweet new avatar DTB.
I have the 4" blocks and I've yet to encounter a problem. However, I would like to ditch the blocks for a set of longer springs when money will allow.
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
