Strange engine tap...?
Old Jan 23, 2010 | 07:33 PM
  #41
flyingbrass's Avatar
How was the exhaust valve out of whack? You had set the valve lash, and so did the mechanic. What that the problem or something else?
Old Jan 24, 2010 | 01:03 PM
  #42
Ajm1991's Avatar
"Out of whack" was his choice of a description for it, Im not entirely sure what it meant. He did say the exhaust valve adjuster was a half a turn in (so too tight i assume) I guess that when my friend mechanic and I did it, we started the issue. Its strange to me tho that over time it got louder, and louder and finally to the point of "wow my truck about to do something i really dont want it to loud". It was a locally owned shop here (E&F Automotive). I know i probably havent used the proper terms for half the things ive said, but E for effort
Old Jan 24, 2010 | 01:17 PM
  #43
Riozpr's Avatar
hello i had a 94 22re before my 86... it had an awful loud tapping noise i adjusted the valves and later on found out it was my timing chain.. it had play and it was timr for a new one... the noise was made all through all RPM's .. you can check if its lose by removing the valve cover
Old Jan 24, 2010 | 02:03 PM
  #44
Ajm1991's Avatar
Thanks for the reply Riozpr, the engine has 11k on it i installed it in August. its got the metal-backed guides also. So Im pretty sure that wouldnt have caused a noise issue. He also did my control arm bushings too so now the entire truck is nice and tight. Im just down to the idle drop issue. Its suppose to kick up to compensate for the drag by being in gear, right??
BushPig
Oct 29, 2022 06:26 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
ryerye13
Jul 14, 2015 08:27 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
