Strange engine tap...?
Old Nov 22, 2009 | 10:25 PM
Ajm1991's Avatar
Thats sorta why I lean toward an issue with the valves also
Old Nov 22, 2009 | 10:32 PM
91_TOYOTA_4x4's Avatar
wow decent millage, im getting about 16 mpg all round lol, 4wd hey.
valves could be it? how does it run does it have less power than before? winter gas drops your mpg so could be that?
Old Nov 22, 2009 | 10:41 PM
Ajm1991's Avatar
Yeah it just doesnt have the power it should (comparing to the old engine) it feels like its gotten worse progressively alond with the tap. You can actually hear it out the tailpipe
Old Nov 22, 2009 | 10:42 PM
Ajm1991's Avatar
And winter gas could be a factor.... i live in Arizona so our winter isnt much of a winter lol
Old Nov 22, 2009 | 10:47 PM
  #25
haha true lol arizona must never see snow eh? i have always wanted to go there and wheel out in the canyons like clint eastwood driving a yota lol. you would think here in B.C. we get alot of snow but its nothing much, like if we do get snow its usually under a foot and only lasts a couple days haha
Old Nov 22, 2009 | 10:53 PM
  #26
Ajm1991's Avatar
[QUOTE=bend;51289021]it is a combination of injectors/valves[/QU
Old Nov 22, 2009 | 10:57 PM
  #27
Ajm1991's Avatar
There ya go!!! Haha. And parts like Flagstaff and Sho lo do but very very rarely here in tucson
Old Nov 22, 2009 | 10:59 PM
  #28
? i dont see anything? lol
Old Nov 23, 2009 | 05:26 AM
  #29
rustypigeon's Avatar
I'll bet you have a rocker arm hitting the valve cover. This is common with the 22r. You can't tighten the valve cover down to factory specs or it will make contact with the rockers.
If your valve cover gasket and rubber washers are not new, I would replace those. Then tighten the valve cover down until the rubber washers just barely start to compress. Then see if the noise stops.
Depending on how long the rocker has been hitting the cover, you may be able to see the shiney spot where they made contact.
Old Nov 24, 2009 | 07:11 AM
  #30
Ajm1991's Avatar
I didnt even know that was possible, actually that could be part of it since i know they are too tight {we reused them} i will gocheck that out right now. Also I tried to run some cleaner thru the injectors, with no results Is there another method of cleaning them more thorouglly?? excuse the spelling
Old Dec 22, 2009 | 09:48 PM
  #31
Ajm1991's Avatar
Just an update. Ive replaced the grommets on the valve cover to see if they were too smashed down. With no new results. Ive also tried injector cleaner in a few tanks and nothing. I tried to retime it and honestly its starting to sound louder?? It also accelorates much slower than it used too. WOT it takes about 8 seconds to 45mph. And BTW while i was at it i did a compression test 181-179-180-181..... just to count that out.
Old Jan 5, 2010 | 09:13 PM
  #32
Ajm1991's Avatar
Ive currently parked the truck because of the issue its gotten a little to loud for me to risk trashing a new engine. I can here the sound thru the exhaust. I also noticed it seems to be running rich? when you depress the throttle past half it has a light puff of black... I also replaced cap, rotor, plugs and wires with Denso parts. Any more input?? I know this is probably just as puzzling to everyone else as it is myself.
Old Jan 5, 2010 | 09:22 PM
  #33
abecedarian's Avatar
adjusting the valves will take up the slack on the bottom side of the rocker shafts and keep the valves opening properly, but what about the gap at the top?
When the cam releases the valve, there's all that gap on top that you can't get rid of.
Old Jan 5, 2010 | 09:24 PM
  #34
peow130's Avatar
did you tighten your exhaust manifold?
Old Jan 5, 2010 | 10:17 PM
  #35
Erik Beeman's Avatar
DUDE. you have mechanical rockers, it's the nature of the beast to be loud. they all do it
Old Jan 6, 2010 | 05:52 AM
  #36
pruney81's Avatar
You'd be surprised how long these engines can run while being extremely loud. A 22re will just keep beating along.
Old Jan 19, 2010 | 08:17 PM
  #37
Ajm1991's Avatar
Well another update on my truck. I took it to a real mechanic (for once) and he set the valve lash. All but 2 were right on. And it didnt make anything but a minimal difference. He said tho that i have very low oil pressure (not sure how he found this out i dont have the sr5 gauges, just idiot lights). Could this contribute to the loud top end? Is there anything that could be blocked to cause this progressive problem? Thanks for the responses all
Old Jan 19, 2010 | 09:10 PM
  #38
flyingbrass's Avatar
What did he say about the noise you're hearing?
To check the oil pressure he probably screwed in a mechanical oil pressure gauge, which you can also do yourself. $10 for a tester plus a fitting or two. What was your oil pressure? A number by itself doesn't mean much. Need to know at what RPM and whether the engine was up to operating temperature.
Years ago, my 22R suddenly started making an extremely loud tapping sound after stopping at a convenience store. I pulled over, my initial thought being that maybe a belt had broken, part of it stuck and flapping against something. It was that loud. I didn't see anything wrong.
I drove home and checked the valve clearances. They were all ok, yet this singular, loud, RPM-based tapping noise persisted. I couldn't pinpoint it. It seemed to be coming from the top end, but I could also hear it below. In retrospect, I wish I had tried using a mechanic's stethoscope.
The tapping persisted, eventually tapering off over several months, and finally went away. Later, I discovered I had a burned valve, though I don't know if the issues were related. Strange.
In your position I'd look further into the oil pressure situation. A mechanic said it is low. Get more info from him and/or check it yourself and go from there.
Old Jan 23, 2010 | 10:55 AM
  #39
Ajm1991's Avatar
Its fixed! Somehow he overlooked an exhaust valve that was entirely out of whack. It is the quietest 22re ive ever heard, Ive been so used to the loud valvetrain a few times since i got it back i actually thought it died while coasting lol. Now i just need to figure out why the idle drops almost 400 rpms when you put it in gear (D,2,L,R).
Old Jan 23, 2010 | 12:18 PM
  #40
Sounds to me your tranny is going out.
