Still runs bad when warmed up
Old Nov 5, 2010 | 09:49 AM
BajaRunner's Avatar
Well, I retorqued the exhaust bolts again, but no difference.
Attached are the burnt areas on the manifold gasket.
I also took another video of the exhaust bump/bubble/hiccup I am getting, which I feel is related to my power issues.
Anyone hear anything out of the ordinary? Does it sound like an exhaust leak? I dont see how a manifold gasket could blow out in 2 days?
I tried stalling the engine with a 2x4 on the exhaust pipe, as well as a rag, and it wont stall out. I can't feel exhaust gasses leaving the manifold gasket. The entire exhaust is welded, so no leaks downstream. Its all brand new within the last 6 months as well.
HERES THE VIDEO
Heres the photos
Old Nov 5, 2010 | 11:17 AM
Moonfish's Avatar
Originally Posted by razed
1) warm the engine up to normal temp
2) jump the appropriate terminals in the test connector
3) set the timing
4) set the idle
5) check the timing; go to step 3 if the timing needs adjusted
6) go to step 3 'cause I know you skipped 4 & 5
all your engine settings are made with the engine warmed up: idle speed, timing, valve clearances... ALL of them.
If you make the engine run well when cold, you are only compensating for bad adjustments and sensor readings when the enigine is warmed up. Think about it. You have a "COLD START INJECTOR" and "COLD START INJECTOR TIME SWITCH"... they don't say "WARM START" do they?
It's all troo. It's actually painful to watch someone ignore good advice
In the vid it sounds like it's idling way too fast? Mine has that exhaust leak and runs great.
Old Nov 5, 2010 | 02:01 PM
BajaRunner's Avatar
Are you talking about me ignoring the advice? I have already done this, and shown I know how to do this... I've been trying to get this truck running correct for 3 months and I've set valves, adjusted timing like 40 times.
Also I had the accelerator down so thats why it sounds like its idling high. I have it set at about 850 which I like.
Old Nov 6, 2010 | 12:08 PM
BajaRunner's Avatar
Can anyone make anything of the video/pictures I attached? I'm getting ready to sell the truck if I can't figure this out. Its just been a pain in the ass.
Old Nov 6, 2010 | 12:53 PM
  #25
Moonfish's Avatar
As long as you're connecting the diagnostic jumper and the rpm changes before you time it, you're A-OK as far as I know. I can't imagine how many times that has been done wrong by many people including myself. I think I did it wrong many times if I remember correctly. I think I also put the distributer in one tooth off so it wouldn't quite reach the proper mark.
The battery cables are sometimes known to go bad. It's cheap to replace them and they influence every aspect of the motor when it's running. Mine didn't just not run, it dogged around real bad. It's amazing how tiny the wires are and how poorly they are connected.
You could run the unlit propane torch around the hoses and try to find any leaks.
Bogging down between shifts might be the idle set too high.
Old Nov 7, 2010 | 08:00 AM
  #26
BajaRunner's Avatar
I wouldn't doubt its an electrical problem. I am unsure if its normal or not to have the car bog when I turn on my electrical fan.
Also, when I put on my turn signal, the voltmeter on the dash clicks back and forth, but I don't know if thats just normal or not.
Old Nov 8, 2010 | 07:24 AM
  #27
BajaRunner's Avatar
Can anyone listen to the video and give an opinion on what that stutter is in the exhaust? I move the camera to the exhaust pipe towards the middle of the video, you can hear it better.
Old Nov 8, 2010 | 07:40 AM
  #28
xxxtreme22r's Avatar
kinda sounds normal to me, anytime you run it like that at idle with that much throttle your bound to have a little pop like that.
Old Nov 8, 2010 | 09:01 AM
  #29
ducaticdude's Avatar
hi i workon diesel engines but i had something similar the other day. compltely different vehicles but just thought id mention doing the computer. checked everything on the truck, swapped the computer. perfect-ish. (turns out the test ecm was bad as well but a different bad)
Old Nov 8, 2010 | 09:27 AM
  #30
Spec is not 850, whether you like it or not. You set things how you want and then complain about the computer doesn't work? Have you ever considered that what you like isn't right?
Haha this is why I like my carbed truck. I can do what I like and the motor is still happy.
Old Nov 8, 2010 | 09:43 AM
  #31
until you start pushing the air bypass and fuel jets...
in which I still think I have to do with my weber. Plugs aren't telling me otherwise though which is why I haven't re-jetted yet.
Old Nov 8, 2010 | 10:09 AM
  #32
andykrow's Avatar
Really? Clearly he follows directions and I HIGHLY doubt having the idle a tiny bit high is causing this issue. FYI I see everyone saying to jump the test connectors but the FSM does not say to do this to set idle on the 22-re. From the FSM:
13. ADJUST IDLE SPEED
A. 22R-E AND 22R-TE ENGINE
(a) Preparation
- Air cleaner installed
- All pipes and hoses of air intake system connected
- All vacuum lines connected (i.e. EGR system, etc.)
- EFI system wiring connectors fully plugged
- Engine at normal operating temperature
- Accessories switched off
- Transmission in "N" range
(b) Connect a tachometer to the engine
Connect the tachometer positive (+) terminal to the ignition coil negative (-) terminal
-Notes on hooking up tach omitted-...
(c) Race the engine at 2500 rpm for approx. 2 minutes
(d) Set the idle speed by turning the idle speed adjusting screw
Idle speed: 22R-E 750rpm
(e) Remove the tachometer
And that's it. Nothing about the test connector. Where do people get that from? This is from my 88 4runner FSM but I've looked at other years and none of them say jump the connector to test idle. And FYI I like my idle around 850 as well and my truck runs perfect.
Old Nov 8, 2010 | 10:11 AM
  #33
andykrow's Avatar
Baja I think you need to somehow get hold of a known-good ecu and swap it in.
Old Nov 8, 2010 | 10:13 AM
  #34
the test connector your talking about and probably confusing is to set the timing. When connected properly the idle will go down because the timing will get less advanced.
Old Nov 8, 2010 | 10:22 AM
  #35
andykrow's Avatar
Yeah I just hear people always say set idle with the test connector jumped. there's a post in this thread that says to do it.
Old Nov 8, 2010 | 04:35 PM
  #36
BajaRunner's Avatar
When was I complaining the computer didn't work? So you're saying my power issues are all due to my idle being set to 850? I'm fairly certain that the tag under my hood states to set at 850 for 4x4 trucks?
I mean come on, its not that big of a deal. Its not the reason why its causing the problems I am having. I've been working on this truck the last 3 months making sure everything is at a stock configuration, like cam, rockers, ignition, etc.
I set my idle correctly when I adjust the timing anyways.
If I sit at idle with when the engine is cold, I do not get a bump in the exhuast. This still seems like a misfire to me. The whole engine jumps, and the RPM surge. This only happens when the engine hits operating temperature.
Old Nov 8, 2010 | 04:51 PM
  #37
cap, rotor, plugs, wires they are all new right? plugs gapped correctly? what plugs?
Old Nov 8, 2010 | 07:26 PM
  #38
BajaRunner's Avatar
All are from Toyota. I tried swapping them with NAPA parts just incase I didn't get a defective Toyota part. But put the Toyota ones back in. The plugs are from Toyota too, they are Denso. I had NGK in there as well. Plugs gapped via FSM spec.
Like I said, the truck ran supurb for 2 days after I did the HG. AFter I noticed the change, I rechecked valves, and timing. I re-torqued head bolts, and retorqued exhaust bolts when cold.
Old Nov 8, 2010 | 08:31 PM
  #39
JDS1992's Avatar
no white smoke coming out the exhaust right? , didnt see any in the vid so headgaskets fine..speaking of exhaust leaks..my muffler is split in two, at the bottom it makes a rattling noise really annoying, do you guys think it would sound better if I cut the muffler out right after the cat? (its on my 92 3.0L)
Old Nov 9, 2010 | 06:31 PM
  #40
SoCal4Running's Avatar
No .
