Starting Weirdness
Old Jul 22, 2007 | 02:53 PM
ToyYoda's Avatar
Starting Weirdness
Every now and then when I get in my truck to start it, it just cranks and cranks
and cranks but if I stop and try to start it again it cranks over but sometimes
won't stay running and die a few times before it starts and runs like it's
supposed to. I've replaced the fuel pump and cleaned the cold start injector. I
haven't replaced the fuel filter though. Does anyone have any ideas what this
is? It's a little embarrassing when my friends get all worried because my truck's
not starting. I just always say "Don't worry, it'll start...it does this all the time."
and it always does start but I'd like to get it fixed because I know it shouldn't be
doing that.
Old Jul 22, 2007 | 03:36 PM
84sr5yoty's Avatar
doing that.
Does it do this when the engine is cold or hot?
Old Jul 22, 2007 | 07:45 PM
ToyYoda's Avatar
Only after sitting for a few hours after driving.
Old Jul 23, 2007 | 08:40 AM
ToyYoda's Avatar
Anyone?
Old Jul 23, 2007 | 06:20 PM
84sr5yoty's Avatar
Classic symptoms of a bad Cold Start Injector Time switch. I can get you a part number later tonight.
Old Jul 23, 2007 | 06:35 PM
Guardian_Saint's Avatar
...Im also having this problem on my 3vze, but just today I unplug the fuel line off from the FPR and start it and it fire right up so I don't know if I got it fix yet so still testing it, I let you know if this is it. I'm thinking a bad FPR so if you have one on a 22re then check for that, might want to unplug it and start your truck to see if it fire right up, and be very careful if it fire up the fuel will boost out from the FPR and will cause a fire hazardize so don't smoke ( if you smoke ) What I did was get me a longer fuel line and plug the FPR so the fuel will not spill over the engine. Otherwise I'm thinking may it have been cause by vapor lock?
Old Jul 24, 2007 | 09:36 PM
ToyYoda's Avatar
A part number would be nice...and a place to order it from. I'll check the ohms and clean it off to see if it improves.
Old Jul 25, 2007 | 06:27 AM
gametom's Avatar
I have one for a 91 22re if it's the same and will fit just pm me if you want it
Old Jul 25, 2007 | 07:06 AM
4Crawler's Avatar
Here is a simple test to try before replacing parts:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Doug4320
Mar 24, 2018 10:11 PM
jon.r
Jul 11, 2015 03:34 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
