Starting problems :(
Old Dec 7, 2007 | 05:54 AM
magic's Avatar
Hi Everyone,
I have a 90 pickup 4x4 v6, I can not get it to start!
It turns over, after about 10 turn overs, i smell fuel, so it is getting fuel...
Someone told me it could be a relay?? What emse should i check?
Thanks
Old Dec 7, 2007 | 06:16 AM
jagger_snitt's Avatar
Are you getting fire? Has the truck been sitting?You know it isn't the starter,or safety switches because it's turning your engine over,you know your getting fuel(you can smell it) Well,the next step is are you getting a spark to make that fuel explode?
Old Dec 7, 2007 | 06:42 AM
magic's Avatar
I have been driving it daily, and I am pretty sure it is getting sparks because when it turns over, at a point or two, itit sounds like it is catching than it dies....
Also I just had a remote starter installed, so im wondering if that could be the case.
Old Dec 7, 2007 | 06:56 AM
That sounds like the culprit. I would check all my batter connections and cable connections to the starter.
Old Dec 7, 2007 | 06:57 AM
rdlsz24's Avatar
The remote start installers hosed it.
Rob
Old Dec 7, 2007 | 07:55 AM
magic's Avatar
So you think it is the remote starter could be the issue?
Old Dec 7, 2007 | 10:06 AM
MMA_Alex's Avatar
could very well be. was it installed recently?
Old Dec 7, 2007 | 10:10 AM
Yeah if it was working fine before,that would be my first guess,try giving them a call,and go from there,be nice and explain the situation,normally the company will/can help you out.
Old Dec 7, 2007 | 12:05 PM
magic's Avatar
Thanks,
yes it was installed like 2 weeks before the problems started...
Thanks...
Ill call them
Old Dec 7, 2007 | 12:34 PM
bigt's Avatar
NEW SPARKS PLUGS my truck wouldnt start.... new plugs helped that.. i had the same symptoms as you
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
