starting issues 1990 3.0 v6
Old Sep 13, 2014 | 02:12 AM
two feathers's Avatar
Well still having starting issue and have narrowed down the wire coming out of the distributor cap into the wiring harness. I can move the wire then will start. It looks like a wire may be a short. What is the best way to find the short since it may be somewhere in the wiring harness? Thanks in advance
Old Sep 13, 2014 | 12:31 PM
wyoming9's Avatar
Red face
I would look at the plug where it plugs into the distributor.
That is where wires tend to break if not there look at any places where the wire harness might be rubbing or damaged .
It seems you have a open circuit unless you need to replace a fuse every time.
Old Sep 13, 2014 | 03:38 PM
RAD4Runner's Avatar
Best way is strip the wiring harness and inspect. Our senses, sight, touch, smell, common are the best diagnostic tool. Use them.
JF9243176
Oct 8, 2017 04:21 AM
ZONAYODA
Jun 30, 2015 05:36 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
JF9243176
Jun 24, 2015 04:53 AM
slider417
Jun 22, 2015 10:18 AM
