starter just clicks after installing new hg
Old May 30, 2008 | 05:59 PM
kd's Avatar
kd
i just put a new head gasket on my 22re and when i try to start it it just clicks. anyone know what could be wrong?
Old May 30, 2008 | 06:04 PM
crews462's Avatar
just a click when starting could be the contacts in the starter solenoid. don't know what that has to do with the head gasket? you can clean the contacts or replace the starter.
Old May 30, 2008 | 06:40 PM
95SASMudRunner's Avatar
yea check all your connections and grounds
Old May 30, 2008 | 06:56 PM
MorphiasX's Avatar
You sure the battery isnt low? It doesnt have to be completely dead for the starter to not have enough juice to crank.
Old May 30, 2008 | 08:36 PM
iam_turner's Avatar
I would say this is NOT at all related to the HG, there's an electrical problem somewhere's. As mentioned above, check connections, try to boost, if you've got a voltage meter check your battery voltage. Check contacts on battery, ect...
good luck.
Old May 30, 2008 | 08:44 PM
abecedarian's Avatar
I assume the battery was disconnected so are the terminals tight?
Old May 30, 2008 | 10:00 PM
iamsuperbleeder's Avatar
uh oh, you've don it now... it'll never run again...
jk...
Like other's mention, start with the simple things...
1) Is the battery fully charged? If the HG job took a while, the battery could have drained a bit just sitting around. Try jumping it; if she starts, take her for a drive to recharge the battery, or if you have a charger just charge it over night.
2) Make sure your terminals on the battery are clean and tight; 75% of the starting problems I've seen in the past were caused from a bad connection at the battery.
3) Make sure the connection to the starter is tight and intact. I don't think you would have had to mess with it for the HG job, but just double check it.
Old May 30, 2008 | 11:16 PM
kd's Avatar
kd
thanks, its a new battery i chargerd it too just incase im prob gonna pull the starter and have it tested saturday
Old May 31, 2008 | 11:51 AM
kd's Avatar
kd
i just tested the starter and it passed with flying colors, guess im going to replace the cables, after that the fsm's troubleshooting recs are the neutral saftey switch and ignition switch which hopefully are ok.
Old May 31, 2008 | 11:57 AM
4Crawler's Avatar
Here is a quick check you can do in the vehicle to see where the problem lies:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old May 31, 2008 | 02:31 PM
Kaydon's Avatar
check the fuse.
Old May 31, 2008 | 05:22 PM
Targetnut's Avatar
Does the engine turn over by hand?
If the cam timing is off then the valves and pistons may be hitting each other and preventing it from turning over. of course there could be other mechanical reasons as well
Old Jun 1, 2008 | 07:28 AM
kd's Avatar
kd
i finally got it to run yesterday. the battery to starter cable was fully corroded through, looked fine untill i took the cable out of the plastic shielding. then i could easily see it was expanding from the inside. thanks for all your help and suggestions
SubiKing
Aug 21, 2021 03:57 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
cars-guy
Jul 11, 2015 07:51 PM
colinmil
Jul 6, 2015 04:03 PM
