starter issues
Old Jun 24, 2010 | 03:59 PM
stackedyoda's Avatar
starter issues
i got my 93 from a junkyard for $500, and it has some electrical problems. the main issue is the starter. first it would click at the relay in the passenger side kick panel, so i replaced it and the new one did the same thing, so i got a used started from ebay, it tried to turn once then clicked at the relay, so i got a rebuild kit for my original denso starter and i put it in tonight and the relay is still clicking. i have 3 relays at the kick panel and all 3 do the same thing, anyone have any idea's?
Old Jun 24, 2010 | 04:02 PM
jason191918's Avatar
When you say the relay clicks, do you just mean it is energized...cuz i'm pretty sure that would be a good thing. Were the solenoids ever replaced? What about battery?
Old Jun 24, 2010 | 04:06 PM
it just clicks, i know it is getting power to the relay, so i don't see where the problem would be between the realy and starter, and to the best of my knowledge it is all stock and has 200k on it
i did replace the solenoid with the starter rebuild
Old Jun 24, 2010 | 04:22 PM
91MONSTER's Avatar
Take the starter out of the motor, put it on a board and use jumpers to test it on a battery. It should come out and spin
Old Jun 24, 2010 | 04:23 PM
91MONSTER's Avatar
If it does that then you know your starters good
T_F_E's Avatar
Battery good? Check your grounds.
Old Jun 24, 2010 | 04:55 PM
i did take the starter out and hook the battery to it and both of them spin very slowly and then start to pick up a little speed, but neither of them pushed the gear out so i figured it was normal. i know the battery is good it was one of the batteries out of my dodge
Old Jun 24, 2010 | 06:37 PM
Brian Pearson's Avatar
I agree check all the grounds if it just clicks then you know your getting power but a bad ground
Old Jun 24, 2010 | 06:43 PM
it should push the gear out. you have a solenoid issue
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
mluz013
Aug 2, 2015 05:00 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
