Spark plug wire holder
Old Sep 8, 2019 | 10:26 AM
Spread5150's Avatar
5 Year Member
I noticed my spark plug retainers have become brittle and broke. Good timing since this truck is new to me and I have no idea when these beldon Napa wires went In. I decided I’m going with ngk or denso wires but my questions is if the wires come w the retaining clips. Toyota “thinks” they do. But they are not sure and have to order them. The ngk in photos I see do not.
I dont want to order the clips and the 7mm ngk do not fit them. And I don’t want to order the denso for double the price and find out they do not come with them either.
The part in question is this ... https://www.yotashop.com/toyota-pick...SABEgICrPD_BwE
thanks again everyone here
Old Sep 8, 2019 | 10:33 AM
superex87's Avatar
They do not come with the wire holders. LC Engineering makes some real nice ones.
Wire holders
Old Sep 8, 2019 | 11:08 AM
Spread5150's Avatar
5 Year Member
Thanks for the quick reply. If I go with the ngk wires as I plan they show to be 7mm wires. Would the factory wire holders work with these or do I need something different. The ones above show to be for their pro wires which are pretty heavy.
Old Sep 8, 2019 | 12:07 PM
superex87's Avatar
Factory holders should work with 7mm.
Old Sep 8, 2019 | 12:58 PM
scope103's Avatar
Or, you could go with OEM https://www.yotashop.com/toyota-pick...r-19941-65010/
Old Sep 9, 2019 | 02:57 AM
arlindsay1992's Avatar
OEM wires (not Denso, Sumitomo from the dealership) come with the clips already installed and arranged perfectly.
Old Sep 9, 2019 | 04:14 AM
keycw's Avatar
5 Year Member
Wire holders
this is false. a new set of wires from the dealer comes with the wire stays.
Old Sep 9, 2019 | 04:22 AM
Paul22RE's Avatar
5 Year Member
Yes, part # 90919-29055 comes with all the wires & holders for a 22RE.
Old Sep 9, 2019 | 09:17 AM
old87yota's Avatar
The part linked in the original post is for a 3VZ-E, so I assume that is the engine we are working with.
The 22R-E factory spark plug wires are made by Sumitomo (they also make the majority of the wiring and connectors for your truck, Yazaki makes some connectors and other electrical components for our trucks too).
I do know that the 22R-E spark plug wire set does come with the wire holders pre-installed.
I am pretty sure the 3VZ-E wire set gets the same treatment.
Old Sep 9, 2019 | 09:22 AM
keycw's Avatar
5 Year Member
well I look like an a**. I would find it weird that the 22re comes with wire stays but the 3.sl0w didn't. even the wire set I bought for my 67 fj40 came with wire stays.
Old Sep 9, 2019 | 09:35 AM
Spread5150's Avatar
5 Year Member
Mine that have crapped out are the ones that mount to the bolts on the timing cover.
Old Sep 9, 2019 | 10:06 AM
keycw's Avatar
5 Year Member
oh. yeah those aren't oem. I think someone above mentioned lce, Ive seen them on their site.
scope103's Avatar
Originally Posted by scope103
These?
Old Sep 9, 2019 | 10:17 AM
keycw's Avatar
5 Year Member
these are the bolt on ones , sometimes called looms.
Old Sep 9, 2019 | 01:33 PM
Spread5150's Avatar
5 Year Member
The part I’m looking for looks just like the one I put in the original post. The only thing is that one says it’s for models up to 92. I have a 94 so I’m just worried about that
Old Sep 9, 2019 | 04:03 PM
scope103's Avatar
Well, this dealer https://parts.lakelandtoyota.com/p/_...994165010.html says that part number fits 1989-1995. (It also says Toyota doesn't stock them anymore.)
Since I have a '94, I'd be interested in hearing what you get, and where.
https://www.toyotapartsdeal.com/oem/...941-65010.html
https://toyotaparts.mcgeorgetoyota.c...ord-1994165010
https://www.ebay.com/i/123802550024
Old Sep 9, 2019 | 05:15 PM
superex87's Avatar
I did not realize the OEM wires cam with the holders. Good to know.
Old Sep 9, 2019 | 07:49 PM
Spread5150's Avatar
5 Year Member
well I went with these.
I really wanted to go with ngk wires since they could be had for 40-50 bucks.
Two of these and the ngk wires do not add up to the oem price. If they don’t work I’ll check a junk yard or out come the zip ties.
Old Sep 13, 2019 | 10:31 AM
Spread5150's Avatar
5 Year Member
So I ended up going with the factory equipment. I was missing so many of the holders that I figured it would be dang near the cost of factory wires to replace them all and buy the ngk ones. You can’t really see from the factory diagrams which clip you are getting so to avoid headaches. Shipping costs and guessing this worked out.
Yazaki wires are what came with part number 90919-21528.
All holders and clips came with.
Old Sep 14, 2019 | 01:27 PM
wallytoo's Avatar
yeah, so that isn't the case. the originals in 1987 and 1988 were made by yazaki (both of my '87s had date-stamped 1986 yazaki plug wires), and now (2019) are made by sumitomo.
