And so the 22re rebuild begins
Old Aug 15, 2009 | 05:51 PM
  #121
olharleyman's Avatar
OK what I figured out so far
1. I set the timing to 8 and it seems to really like that while it idles but it just don't seem to be right with the idle screw , I can turn it either direction and get almost no difference.
2. After turning the idle screw out quite a bit it seems to get a pretty good idle now then i accidentally leaned on the bent rubber tube from the plastic tube to the plenum and it got all kinds of weird so after looking at it there is a good size crack in the last of the factory bends just before the plenum connection and I think it is getting to much air , is the possible?
3. IT SOUNDS GOOD WHEN IT WAS IDLING REASONBLY WELL
4. I need to find one of them tubes so if anyone has one please let me know if I don't get one from the stealership first. I also have my friends wife going to leaned me a mic for my computer so I will be able to make a video for posting I believe.
Old Aug 15, 2009 | 06:06 PM
  #122
93YotaGuy's Avatar
What rubber tube from the plastic tube to the plenum?
Old Aug 15, 2009 | 06:16 PM
  #123
The one from the afm to the plenum right where the plastic ends and the rubber connects to it then to the plenum connection the big opening
Old Aug 15, 2009 | 06:22 PM
  #124
93YotaGuy's Avatar
If it's the tube that i'm thinking of then how did you manage to bend that tube?
Wonder how it managed to get a crack on it.
I wish I could help you but those are the only pieces I have no extra's for.
Cover it with some electrical or duct tape for now and pick up that piece at your local junkyard. I'm sure they'd only charge you a few bucks
Old Aug 15, 2009 | 07:08 PM
  #125
Here is the part and where it belongs that is giving me the troubles I believe
Old Aug 15, 2009 | 07:13 PM
  #126
93YotaGuy's Avatar
yeah that sucks dude. A ton of electrical tape will work until you get it fixed
Old Aug 16, 2009 | 01:43 PM
  #127
Dirt Driver's Avatar
Those cracks will definitely cause unmetered(and unfiltered) air to get into the engine and make it run badly.
Old Aug 16, 2009 | 05:12 PM
  #128
Lumpy's Avatar
Time to do the battery swap!!!
That sucks man, I agree with Dirt, get 2" electrical tape to duct tape for now.
Old Aug 16, 2009 | 06:36 PM
  #129
Well I went to the auto parts store and bought this to hold me over till I can find the correct piece to replace the old one please no RICER JOKES
Old Aug 16, 2009 | 07:24 PM
  #130
93YotaGuy's Avatar
Sweet.. Easy fix I bet...
Now you can put it way below and make it a cold air intake.
Old Aug 16, 2009 | 09:57 PM
  #131
Erik Beeman's Avatar
Harley dude,
Sorry it took so long for a response, I've been gone since early early Saturday morning.
As for start up, no, I did not have any problems. It started up and ran like it was from the factory. You may want to check the timing on the distributor. It is very EASY to have it off by one tooth. It will idle fine with it a tooth off, but will pop sputter and give you the middle finger when revved up. Don't ask me how I know........ Ha Ha.
And as for that rubber booty, I had the same problem dude! My was also cracked exactly where yours is, and my truck ran like Sheet!! This was before the motor rebuilt, but the thing bucked and sputtered like crazy. I replaced it with one from another Toyota from the junkyard, cost me $2, and I've never had a problem since.
Other than that, congrats on getting the beast going!
Old Aug 16, 2009 | 10:11 PM
  #132
Originally Posted by Erik Beeman
Harley dude,
I think the hose is my problem when I crank it over by hand all timing marks line up right on the crank to timing guide , the rotor points to 1 on the dist. and once it gets running for a min it starts to smooth right out but we'll see when I put this temp hose on.
Old Aug 16, 2009 | 10:23 PM
  #133
I could just be that hose. If that hose was cracked it was letting alot more air into the motor than the ECU thought it was, since it was entering after the AFM. That's what can make it sputter like crazy cause it's going way lean. I'm willing to bet that once you got that new piping on, it'll run crisp!
Old Aug 17, 2009 | 07:28 PM
  #134
OK well I should have it all worked tomorrow I believe , my biggest issue is the Supra AFM I think , I got two air flow codes so I will be getting the old AFM and putting it back on.
I talked to a guy at L.C.Engineering and he Say's the Supra is fine with a stock set up but it adds to much air with their head and cam unless I reprogram the ECU and $300 bucks don't seem like a fair trade for a few more maybe (1-3 h.p. from what he Say's) trade off so I maybe selling the SUPRA AFM if any of you guy's are interested let me know I have 1 offer out and waiting to see what happens if he don't take it $65 shipping for it.
Old Aug 21, 2009 | 05:42 AM
  #135
OK guy's I got a replacement intake rubber till the new one gets here and here is what she sounds like working almost 100% this is from my web cam and a very cheap mic so the sound quality may not be the best and this is my first time doing a video so here go's
http://s184.photobucket.com/albums/x...ent=085247.flv
OH YA this is the stock AFM on now that I think the big air leak is straight I am going to try the SUPRA AFM and see what I get too , worst case I got to go back to this stock unit right?
Old Aug 22, 2009 | 03:50 PM
  #136
92 TOY's Avatar
that wasn't bad....good job on the video.......now you have to zoom past the camera like BLEEDER for the effect LOL.
are there still adjustments to be made or is this tweaked already?
when will it hit the road?
drive it to the beach this week, i'll be there trying not to drown.
Old Aug 22, 2009 | 03:55 PM
  #137
iamsuperbleeder's Avatar
lol
Old Aug 22, 2009 | 04:32 PM
  #138
92 TOY's Avatar
of course i meant that in a nice way BLEEDER.
just can't get enough YOTA-Porn.
Old Aug 22, 2009 | 04:51 PM
  #139
oh I know, lol
I need to get a make a new video... I've got to do something with these spare wheels and tires in this back yard before I move into my new apartment, cause I can't take them with me... the tires are already half bald, and I think I know someone who wants the rims... but there's enough rubber left to... well... just wait and see
Old Aug 22, 2009 | 06:28 PM
  #140
I would do the zoom pass the camera but I only have a web cam and my laptop battery will not charge/run the laptop so I would need a hella long extension cord
Still working on the bugs so no beach trips for me bummer
Hope to have it running and driving by this weekend have to order a new cam the one that came with the L.C.Engineering Pro Street head cam set up is for a 2wd or car that runs in the high rpm range not this big ass 4x4 going to order a ENGNBLDR 268 by Monday get it installed and go from there.
