Slave cylinder trick?
Old Nov 16, 2009 | 07:34 PM
mmcpeck's Avatar
Anybody got any tricks to get the line off the slave cylinder of a tranny behind a 3VZE?
The thing is pressed right up agaiunst the tranny, don't even see how you could get a wrench on there and have any room to turn it.
Not even a slave cylinder is easy on this truck!!
Old Nov 17, 2009 | 08:00 AM
mmcpeck's Avatar
Somebody's gotta have some advice for getting to that hydraulic line on the slave. I know it's been and can be done, just don't see how you get a wrench on the line.
Thanks.
Old Nov 17, 2009 | 01:15 PM
thedanned's Avatar
Try a crows foot wrench? Never had to do this before. Ill look at mine when I get home.
Old Nov 17, 2009 | 03:16 PM
jreb10's Avatar
I took off the slave on my 1992 3VZE a couple of weeks ago. I used a standard Sears Craftsman wrench (10 mm I think). I reached up from below the connection, sort of, and was able to get enough rotation on each pull so the open end wrench was able to re-engage the fitting. I do recall thinking that a shorter wrench would have been handier.
Try sneaking the wrench up there as far towards the front of the truck as you can. It worked for me.
RobotMoose
Feb 22, 2020 07:44 AM
4.34runner88
Feb 7, 2016 02:24 AM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
Squigglez
Sep 4, 2015 07:33 AM
