Show off your swapped in seats!
Old Nov 19, 2010 | 01:39 PM
yotarover's Avatar
went to the local junk yard today after having a spring stab me in the back. so i traded in 2-93 ford ranger bucket seats my buddy left in my building and the 2 factory seats from my 89 dlx *started to get tired of the 60/40 drivers seat. and got 2 89 runner buckets same color as these Name:  IMG_2429.jpg
Old Nov 19, 2010 | 01:55 PM
Zelephant's Avatar
Originally Posted by shaeff
MKIII Toyota Supra seats, with the driver's side power seat wired up. Super comfy.
Did those bolt right in with no mods?
Old Nov 19, 2010 | 02:32 PM
tumor21's Avatar
x2, ...also curious
Old Nov 20, 2010 | 12:04 PM
nmtoy's Avatar
Originally Posted by tumor21
x2, ...also curious
3rd gen 4runner/Tacoma seats have completely different mounts than older trucks/4runners.
I put a set of 01 4runner buckets in my 92 excab. I had to cut the mounts off the 4runner seats and custom make some mounts out of my 60/40 brackets.
It was a pain...
Old Nov 20, 2010 | 07:39 PM
  #25
Zelephant's Avatar
We were asking about MK.III Supra seats, I believe.
Old Nov 20, 2010 | 08:03 PM
  #26
yeehaw1's Avatar
Wow, really got me wantin to hurry up and find some nice buckets, trashed or not, long as the foams good i'll reapholster them, can't be tha hard can it?
Old Nov 20, 2010 | 08:11 PM
  #27
Teuf's Avatar
Most older driver side buckets are worn n torn on edge, but if you are good with a needle and thread, go for it.
Old Nov 20, 2010 | 08:17 PM
  #28
yeehaw1's Avatar
I wouldn't say good, but proffecient maybe, only one way too find out and that's to try it, Ive been lookin for an excuse to go to the junkyard anyway, may have just found it.
This is my 100th post finally!
Last edited by yeehaw1; Nov 20, 2010 at 08:19 PM. Reason: Just relized this is my 100th post!
Old Nov 20, 2010 | 08:20 PM
  #29
peow130's Avatar
Mini-threadjack, but speaking of seats...
Has anyone swapped in heated seats into 1st gen 4Runner, and if so, from what? My friend's late-model Jetta had them, and they were soooo nice, it got me thinking about if it was possible to swap them in. Anyone try it?
When i swap in seats i'm swapping in powered seats.
prolly next summer or spring.
Old Nov 21, 2010 | 06:56 AM
  #30
brianbloom516's Avatar
need to find good price on good seat covers
anyone know a few good sites to order good seat covers from? my toyota is a work truck and they need to be thick and durable. also some new carpet would be good. i was planning on scotch-guarding the livin hell outta it before i install it.
Old Nov 21, 2010 | 08:41 AM
  #31
toyotabull's Avatar
Ya'll will have to wait till I get back home, but I installed leather seat from an 89 conquest tsi. Black leather, and full adjustable, even to the width on the back from side to side. 4 more days.
Old Nov 21, 2010 | 09:35 AM
  #32
shaeff's Avatar
x2, ...also curious
You can get them to fit with just prying them around but I don't recommend it. Building a custom bracket is the best way to go.
The holes are very close, however.
For reference here's how they're powered:
Seat bottom: front of seat bottom goes up/down, rear of seat bottom goes up/down.
Slider: power slides forward/backward
Seat back: power lumbar, and power side bolsters that really hold you in the seat.
Non-powered: entire seat back can be moved forward/backward (angle) with the adjustment knob, the headrest has four different positions forward/back, and up/down.
And if you get a newer (90+?) set, then the back angle is powered as well.
Old Nov 21, 2010 | 11:36 AM
  #33
Two2Three's Avatar
I put a set of Sparco seats into my 91 MR2, so I will be fitting my stock 91 MR2 Turbo seats into my 87 Truck. I will post pics when installed.
Old Nov 21, 2010 | 11:44 AM
  #34
medic83's Avatar
I will be putting stock leather seats in my truck this next week!! Ill get some pics up when Im done
Old Nov 21, 2010 | 12:29 PM
  #35
BrianJE's Avatar
97 4runner buckets
Old Nov 21, 2010 | 07:29 PM
  #36
Zelephant's Avatar
Awesome, thanks man! If I can find these seats, this is what I'm doing.
Old Nov 21, 2010 | 08:42 PM
  #37
Teuf's Avatar
Old Nov 21, 2010 | 08:46 PM
  #38
defrag4's Avatar
from a 91 4runner sr5 in my 87 4runner
Old Nov 22, 2010 | 01:45 PM
  #39
shaeff's Avatar
No problem. Just make sure you grab the lumbar/side bolster switch out of the center console area of the Supra you remove the seats from, as well as the wiring harness pigtail from that area. There are other power wires (for the seat bottom movement) coming from the floor under the carpet of the Supra- cut those out as well.
Then check out the TEWD to wire them up: http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=097
Old Nov 22, 2010 | 05:06 PM
  #40
ttrmike's Avatar
1987 pickup
Corbeau Baja SS seats with toyota pickup specific mounts.
