Shifter Boot HELP?!?!?!?
Old Dec 1, 2010 | 08:04 PM
Phessor's Avatar
I recently purchased the small rubber shifter boot that goes on top of the transmission over the shifter.
My question is this, how do you get it on?
It has a small hole that will not stretch over the shifter.
Anyone have any ideas?
Thank you, Phessor :cool;
Old Dec 1, 2010 | 08:08 PM
2DoorRunner's Avatar
If i get what you are saying, you are asking how to get it over the shift knob?
Old Dec 1, 2010 | 08:13 PM
Phessor's Avatar
Not the knob, just the shaft.
This is what I have.
http://www.marlincrawler.com/transmi...t-handle-boots
Thank you, Phessor
Old Dec 1, 2010 | 08:17 PM
scuba's Avatar
Try harder.
Old Dec 1, 2010 | 08:31 PM
Okay good, i was going to say.....
Im with scub, maybe a little ky lube will help it on. Always keep some in the tool box
Old Dec 2, 2010 | 05:52 PM
Phessor's Avatar
I will give it a try then.
Phessor
Old Dec 2, 2010 | 05:55 PM
rattlewagon's Avatar
Old Dec 2, 2010 | 06:08 PM
Wrenchinjoe's Avatar
ROTFL !!!
RE-RE, that KY advertisement pic combined with your signature line is freakin' hilarious!
Old Dec 2, 2010 | 06:19 PM
myyota's Avatar
Unscrew the shift knobs and slide it over the shifters.
Old Dec 2, 2010 | 06:35 PM
Phessor's Avatar
It won't rip?
Old Dec 2, 2010 | 06:55 PM
Ok dude i dont know how much more we can help you. Maybe if i try step by step.
1)unscrew shift knobs
2)Slide boot over
3)screw shift knobs back on.
If it doesnt go on with some force or ky jelly, then your going to have to make the hole bigger.
Its pretty self explanatory.
Old Dec 2, 2010 | 07:05 PM
MudHippy's Avatar
Dude! Chill. It's not as easy or as straight-forward as it sounds.
Originally Posted by Phessor
It won't rip?
It shouldn't. I just did this a couple weeks ago on my transmission shifter, and will be doing it soon to my transfer case shifter.
I couldn't figure out how it would fit without tearing either.
Then I read this:
Remove the stock rubber dust-boot from the shifter assembly. It is a tight squeeze to get the boot over the largest part of the stock shifter, but a little lubricant will help. Be very careful not to tear the boot because it will also be reused.
http://www.off-road.com/trucks-4x4/t...com-18917.html
I figured if it needed lubed to come off, it must need lubed to go back on.
I used petroleum jelly. Save the KY for better uses.
Old Dec 2, 2010 | 07:12 PM
Phessor's Avatar
Then I read this:
Thank you!
Phessor
Old Dec 2, 2010 | 07:13 PM
What was stated in your quote is exactly what was said previously.
Yes it may not be as easy as you would think it would be, but i think the proper solution has been stated a couple times already.
Its a shifter boot install, not a sas build.
mwisham
May 26, 2021 02:51 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
89YodaRunner
Sep 30, 2015 02:18 PM
irv
Sep 22, 2015 11:51 AM
