Rust prevention: might be worth taking those interior door panels off...
Old Jun 3, 2020 | 10:31 AM
Paul22RE's Avatar
5 Year Member
This channel at the base of the door had a thick layer of black wet crud that I am almost done cleaning out using a plastic scraper, toothbrush & a lot of compressed air. I should've taken a picture of what it looked like before I started. Perfect place for rust to start:
Old Jun 3, 2020 | 12:39 PM
old87yota's Avatar
That is a good place to clean that most people never think to look!
Thanks for posting!
Old Jun 3, 2020 | 03:22 PM
wallytoo's Avatar
i pull all the interior trim panels every fall in order to coat the inside of the body & doors with fluid film. also clean out all the drain passages in the pinch welds of the rockers.
Old Jun 3, 2020 | 03:30 PM
Paul22RE's Avatar
5 Year Member
Yes, I use fluid film all over: door panels, inside tailgate, up in the wheel wells, behind the rear lights, the voids in the hood, inside the fenders, inside the frame, spare wheel, etc.... Stuff smells great too!
Old Jun 3, 2020 | 03:52 PM
wallytoo's Avatar
fluid film works well, my only problem is the 5 to 7 vehicles i need to treat each year....
Old Jun 3, 2020 | 04:44 PM
5 Fists's Avatar
Good info in this thread! Fluid film eh? Just spray a nice.. film over things and it protects it, good thinking guys, will be adding this to my winter maintenance for sure.
Old Jun 3, 2020 | 04:49 PM
Paul22RE's Avatar
5 Year Member
This gun makes it a breeze to spray: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Gallon jug: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old Jun 4, 2020 | 01:01 AM
RAD4Runner's Avatar
... clean out all the drain passages in the pinch welds of the rockers.
Here in So Cal, at least this^^^
I had a puddle of water in compartment behind the rear wheel-well. Fixed after I cleaned the drain there. Condensation must have built up in there.
Old Jun 4, 2020 | 02:55 AM
wallytoo's Avatar
additional note: i also spray the inside and outside of the chassis, along with most of the underside of the vehicle, front end suspension & steering components, etc.
Chase Forman
Mar 23, 2020 03:49 AM
Corey08cummins
May 7, 2016 06:31 PM
ssorck
Dec 9, 2011 12:24 AM
Yotaboy
Jan 23, 2007 09:02 AM
