Running Lights out?
Old Apr 7, 2010 | 07:48 PM
92yota604's Avatar
Question Running Lights out?
I have a question for u guys, i have 1992 pickup 22r-e, reg cab,and i cant get my running lights to come on and I've checked the bulbs.
Also all of my other lights work (turn, reverse and brake)
Any ideas guys??? gimme a shout
much appreciated
Old Apr 7, 2010 | 07:55 PM
DeathCougar's Avatar
Do the headlights work?
Old Apr 7, 2010 | 07:56 PM
92yota604's Avatar
yes all lights work but the rear running lights
high beams work too
Old Apr 7, 2010 | 07:58 PM
Check for corrosion at the terminals. Brake and running lights share the same socket, so its possible that you have a problem there.
Since the front lights work, you can eliminate the switch or relay as the problem. Get yourself a multimeter and see if you have power through the wire to the socket.
Old Apr 7, 2010 | 08:03 PM
92yota604's Avatar
thanks for the tips ill look into it
LITLRED's Avatar
Get a wiring diagram for your vehicle, a test light, and find where your circuit is open. My test light has an aligator clip on one end ad a very sharp point on the other that allows you to pierce thru wire insulation. These toyotas are ground switched meaning the switch is on the negative side. Check the fuse and make sure the ground is clean and tight. Do you mean your head lights or parking lights?
Welcome to the Forum
Old Apr 7, 2010 | 08:21 PM
92yota604's Avatar
I mean the rear running lights (red) but the bulb illuminates when i press the brake but goes out completely when i take off the brakes. with my light switch all the way on
Old Apr 7, 2010 | 08:32 PM
The brake and running lights share the same bulb, an 1157 which is a dual filament bulb.
Old Apr 7, 2010 | 08:37 PM
92yota604's Avatar
yes i know but only the brake works not the running
weird i know
Old Apr 7, 2010 | 08:42 PM
They rely on separate circuits, so check to see if you have power at the plug. If you do, then you know where the problem is. Weird that both would be out, but I once had both my headlights on my 89 go out at the exact same time. Several switches and a lot of curse words later, i figure out the bulbs were both bad. I know you checked the bulbs already, so just check if you have power at the plug and go from there.
Old Apr 7, 2010 | 08:47 PM
92yota604's Avatar
Ill get out there tomorrow with the multimeter
haha thanks guys
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
