Rocker Arm adjustment ?'s 22RE
Old Aug 13, 2005 | 04:57 PM
brendonv's Avatar
I am planning on doin rocker arm adjustment soon on my 93 pickup, question is, do i just take off the valve cover and go to town, or does the engine need to be at TDC or any other location?
thanks
Old Aug 13, 2005 | 06:55 PM
jimbo74's Avatar
if you are talking about a valve adjustment, the engine does need to be @ a certain position, not sure what the spec is on the 22re. also you will need the tools to do this correctly, and must really also know what you are doing.... not to sound like a punk, but if you need to ask what location the engine shioould be at, i am not sure you know what you are talking about enough to just pop open the valve cover and adjsut things... you need a feeler guage as well... an fsm, or a haynes manual has the adjustment procedure in it for the valves and are easy enough to fine....
looking at your signature, if you did that stuff on your 87, then you do know what you are talking about... however i still say get a haynes manual so you have the info in hardcopy in front of you for reference.....
Old Aug 14, 2005 | 04:23 AM
brendonv's Avatar
thanks, the reason im asking because iw as confused when i read this on 4x4 --wire "Do this for the first set of valves and turn the harmonic balancer 360 degrees. This will move the first cylinder from the compression stroke to the exhaust stroke"
Old Aug 14, 2005 | 06:26 AM
4Crawler's Avatar
Yep TDC for half the valves, then one engine rotation for the other half:
- http://www.off-road.com/toyota/tech/...ves/index.html
88sasturbotoy
Jan 30, 2026 01:57 PM
bigjstang
Jun 2, 2025 03:56 PM
kirkrunner
Jul 27, 2015 07:59 PM
1994toyota
Jul 17, 2015 03:03 AM
razorman8669
Jul 12, 2015 12:13 PM
