removing bed from frame
I am taking the bed off the frame to check out my fuel/brake lines and the fuel tank so I can buy some parts this week and do some work over the 4th of July.
I got all the bolts off (to take the bed off) except the bolt behind the passenger side wheel. However the bolt is held in there to keep from spinning (to allow you to get the nuts loose) is not working since the nut and bolt spin freely.
Any ideas how to get the nut off the bolt? I may have to cut it, which I would do except I do not have a good cutting tool for this on hand.
I have gotten the nut down to the ends of the threads, so I am pretty close to getting it off. I used the jack to lift the bed and I have about a half-inch of slack to use if I need to cut the bolt.
(I have gotten the nut down to the ends of the threads, so I am pretty close to getting it off. I used the jack to lift the bed and I have about a half-inch of slack to use if I need to cut the bolt.[/QUOTE]
get some visegrip pliars or just get a sawzall
all but one were easy. The sawzall took care of that one.
I have read on here about the bed being a 2-person lift. You guys must be like (R)nold. My brother and I were smoked just getting it half off. I just wanted to see the fuel tank and lines (to check their condition) then we put the bed back on.
I had the same problem with one bolt directly behind the cab on the pass. side. Just jack up the bed and use a sawzall. It's what I did and it was quick. While your under there have a look at your spare tire carrier (if you use it).
Be careful of the fuel tank filler when you take the bed off.
I am going to replace the spare tire carrier over the 4th of July when I take the bed off again (this time it was just temporary). I am going to the dealer tomorrow to get a fuel pump braket, fuel lines, replacement hardware to mount the bed to the frame and some various other stuff.
For the spare tire carrier, I am going to take off the stock unit and replace it with the spare wheel carrier off of a new Tundra. I will post some pictures once I paint the frame, bed and install the new parts.
I cut every single bolt on mine with the sawzall
I think the dealership wanted around $10 a bolt? I had a local guy cut me a handful of tabs on a CNC plasma machine that matched the factory tabs. Then I picked up some half inch bolts and welded them to the tabs.
how about using a wrench on both ends if the nut and bolt are spinning?
cut it weld it to the frame and get the bolt off cut it with a saw or something im not sure i dont have a pick ups truck i got a runner but same thing the way me and my buddy got his bed off was we cut holes in the sides of the box chained it to a tree and put the pedeal to the metal lets just say the box and us didnt know what hit us then we saw mom after words it hurt!!!!
I bought some rust converter and chasis black paint for the frame from a local automotive paint supply shop. I am going to use the rust converter as well under the bed and cover that with Rustoleum primer and paint. Overall for a 17 year old truck I cannot believe how little rust there is, considering how most similar trucks around my area seem to be completely rusted out.
I picked up my parts at the dealer today. The bolt that holds the bed to the frame is over $8(!). I will admit to being a Toyota employee, so my purchases added up to $143 (employee price) for the fuel pump bracket (screws and gasket also), two fuel lines and miscellaneous bolts and fasteners. The fuel pump bracket alone was $131 list price.
I already had the Tundra spare wheel carrier so I am not sure what that cost at the dealer but I am looking forward to storing my spare under the bed again.
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
Backcountry411
Jul 24, 2015 08:06 AM
