Removing Alternator Bracket
Old Aug 26, 2008 | 12:02 PM
bajaguy's Avatar
Hey guys,
Im trying to remove the upper alternator bracket on my 22re and can not find the second bolt that is holding it down. I removed the 14mm bolt that goes through the block but cant find the second bolt that is still holding it in. I circled the bolt I removed in red in this picture.
Thanks
Old Aug 26, 2008 | 12:15 PM
muddpigg's Avatar
If memory serves me, its @ the same location or area as the dipstick support is. Don't know if you need to remove PS pump to get to it, I've always had it off anyways.
Why you taking the bracket off anyways?
Old Aug 26, 2008 | 12:19 PM
bajaguy's Avatar
Im switching over to a GM alternator and have a new bracket that I need to install in place of the stock one. I'll check around the dipstick area.
Thanks
Old Aug 26, 2008 | 12:27 PM
4Crawler's Avatar
If you are talking about the tensioner bracket (below), only the one pivot bolt (the one you circled) and the lock down bolt in the slot:
This tensioner bracket pictured above is the exact one off my 1985/22RE engine.
Old Aug 26, 2008 | 12:38 PM
bajaguy's Avatar
That's it but I removed that one bolt and it still will not come off. The alternator is off already. I hope I dont have to remove the power steering pump in order to get it out.
Old Aug 26, 2008 | 12:41 PM
4Crawler's Avatar
Might just be a little bit deformed where the pivot bolt is and that is holding it in place. I recall taking mine out with the p/s pump in place, but that was about 9 years ago.
Old Aug 26, 2008 | 12:43 PM
muddpigg's Avatar
i'm pretty sure there's a dogleg that comes off the rear of the bracket and ties in to where the dipstick is mounted on the '86. I'll go look.
Old Aug 26, 2008 | 12:46 PM
muddpigg's Avatar
yep there is on mine. You may be able to get it off with out taking PS pump off but it'll be tight. Good luck.
Old Aug 26, 2008 | 01:01 PM
DeathCougar's Avatar
That is only for early 20 and 22R engines.
The 85+ alternator brackets have two mounting positions. On that he circled in red, and the other bolts to the side of the head in the same place the dipstick tube bolts.
Old Aug 26, 2008 | 02:52 PM
bajaguy's Avatar
Thanks, I will go and take a look at it later on.
Old Aug 26, 2008 | 02:58 PM
abecedarian's Avatar
in the following pic, you can see the bracket ear reaching over the top of the water pump fitting, just behind the fluorescent green bracket just below the center of the pic and it's bolt holds the dipstick tube in place (hard to see but it is black)
(credit to 4Crawler for the pic)
Old Aug 26, 2008 | 03:46 PM
bajaguy's Avatar
Thanks guys for all the help! I just got it out. It wasnt hard to get it out either with the PS pump still their. I'll post some pics of my GM alternator once I get it in.
Old Aug 26, 2008 | 07:12 PM
muddpigg's Avatar
It'd be cool if you showed along the way pics, the kind I never have patients to take. I'm interested to see the route you take and the way you wire it.
Old Mar 6, 2012 | 09:23 AM
navig8r2003's Avatar
How did you finally get it out?
Thanks
navig8r2003
1993 Toyota pickup
Stock 22R (working on a rebuild)
4:88's
32" mudders
Lockers front and rear
Old Sep 11, 2020 | 07:45 AM
surfclimb85's Avatar
Do you remember if the bottom bracket was threaded when you removed the alternator? The bolt that allows it to pivot had a rounded head so I grinded it off. I can't tap the bolt out so it is either seized or threaded but I can't tell.
Old Sep 11, 2020 | 06:37 PM
Co_94_PU's Avatar
Pretty quick check is shove your hand in there and feel if there is a nut..
Your description is vague but I'm going to assume you mean the top bolt which pinchs the mount and keeps the alternator from pivoting.. Yes this is threaded into the alternator body.
80Truck
Oct 12, 2025 07:25 PM
redneck17
Oct 29, 2015 09:09 PM
Sep 4, 2015 09:27 AM
shisha1999
Aug 14, 2015 01:33 AM
msane99
Jul 17, 2015 10:13 AM
