remove/install wires 22R fuse block
Old Feb 2, 2020 | 05:57 AM
Mr. Z.'s Avatar
Greetings,
As I attempt to solve some wiring bugs on an '86 p/u I was hoping for some help.
I'm working on the blade fuse (15amp) wires that feed the fuse block by the driver's kick panel.
Questions:
How are the wires removed from the fuse block?
If one side of a blade fuse does not have a wire, but the connector is in the block, how do you get it out?
I've tried pulling gently on the wire while pushing on the other side, but I don't want to break anything.
It feels like there is a tab or something holding it in place that I can't find...
Any suggestions are welcome!
Cheers
Old Feb 2, 2020 | 08:00 AM
Paul22RE's Avatar
5 Year Member
Yes, there is a tab that locks those female spade terminals in place so they can't pull out easily from behind. Using a tiny flat head screwdriver from the front can bend those tabs back towards spade so they slide out from the back. Those tabs will have to be re-positioned again so they lock spade back in place when you need to lock them back in.
Old Feb 2, 2020 | 10:23 AM
Mr. Z.'s Avatar
Thanks for the reply!
I'll give it a try!
Cheers
Old Feb 4, 2020 | 06:37 PM
RAD4Runner's Avatar
Originally Posted by Paul22RE
Yes, there is a tab that locks those female spade terminals in place so they can't pull out easily from behind. Using a tiny flat head screwdriver ...
Yup. Tiniest straight-slot jeweller's screwdriver and good lighting would help.
5280jo
10
Jul 13, 2015 10:05 PM
KBar
Aug 26, 2013 09:34 PM
michalik_piotr
Aug 9, 2010 12:14 PM
forwardtocharis
Jun 7, 2008 08:06 PM
WatsonMD
Jan 2, 2004 08:05 PM
