Rear window switch???
Old Mar 21, 2019 | 11:25 AM
NYHumpinUtah's Avatar
Yah dropzone , you are correct once again. Just went through the FSM and saw the up/down switch. Guess I'll be looking for one of those.
Thanks
Old Mar 22, 2019 | 08:10 PM
millball's Avatar
Just as a heads-up to anybody working on these windows/switches:who has no wiring diagrams::::
None of the switches apply battery voltage to the window motor.
They only act on the relays in the window control module behind the driver side rear panel.
Not wise to put power to any switch wires.
Old Mar 23, 2019 | 10:11 AM
dropzone's Avatar
Fossilized
interesting. I will need to check mine (94) . I could have sworn one wire was hot when I wired an interior switch in the back. It works with out the ignition turned on, similar to the rear window key switch.
And for the OP he is just needs to get the rear window down so he can pull the tailgate from a parts 4runner.
Old Mar 23, 2019 | 10:23 AM
millball's Avatar
I wired an interior switch into my '95 using an extra console switch I had. Center went to ground and up to pin 9 on the control module-- down to pin 17.
These are the same terminals that the rear key switch acts on. The module has power even when Ign key is off. Grounding either of those pins moves the window, at least on a '95
Old Mar 23, 2019 | 11:33 AM
  #25
dropzone's Avatar
Fossilized
that makes sense..it's been about 2.5-3 years since I had it apart to wire that switch
Old Mar 23, 2019 | 08:36 PM
  #26
RAD4Runner's Avatar
Guys,
We're overthinking this. LOL
O.P. does not want to fix nor troubleshoot the window. It is a parts truck.
He just wants to roll it down, so yes, battery power directly to window motor is all he needs to do.
^^^ implies that you are not trying to fix the window system but merely want to lower the window
Originally Posted by Jbiggs
yes that's all I want, the tailgate and window are worth more then the rest of it...lol
Zeb Wainwright
Mar 27, 2017 07:51 AM
El_Estrago
Jul 25, 2011 03:18 PM
1993F250
May 26, 2011 10:12 AM
prhime
7
May 19, 2009 06:44 PM
