Rear window switch???
Hello there I am trying to bypass the rear window switch that is located between the front seats, I have a 94 4runner parts vehicle that has no switch the window is up and I want to lower it. I was hoping there might be a way to put 12v directly to the motor from the switch connector?
Thanks! |
You could use the pin from your tail light harness to create a jumper
Have a 92, and I believe that when I removed the console the switch wasn't plugged in and the window still worked. I'll check it out later today and let you know.
Originally Posted by NYHumpinUtah
(Post 52420762)
The window is activated by the key switch for up and down
(Post 52420764)
Not the ignition switch, the lock switch on the tailgate.
Do you have the battery connected? Do you have power to the truck? Can you turn on your ignition and see the dash board lights? If the door open light is on you can't open the window, you need to play with the tailgate and try and get the door open light to go off. Help this helps |
as stated above, just insert your key into the lock cylinder on the tailgate and turn the key, one direction raises the window the other direction lowers it. the center console switch rarely goes bad. more likely the control box in the driver side panel behind the front seat.
(Post 52420766)
also should mention that if the switch under the the hardtop bolt isnt depressed, the interlock prevents operation, and if the rear wiper isn't seated properly, it will trigger. AND if the window isn't up all the way and the wiper is also not seated at the same time, you've slipped into the twilight zone. try disconnecting the rear wiper motor, check the bolt switch (driver side near the rollbar I believe) and then try the key in the tailgate lock cylinder.
Originally Posted by keycw
(Post 52420771)
If you can access the motor in the tailgate from the inside and apply your ground and 12v that should work. You'll need to have long enough wires that will be out of the way of the glass and gears.
Originally Posted by Jbiggs
(Post 52420772)
It's a 95 4runner no roll bar. But thanks anyway
(Post 52420775)
haha I feel dumb I was trouble shooting you through a 1st gen. sorry.
Originally Posted by se7enine
(Post 52420774)
(Post 52420754)
... I have a 94 4runner parts vehicle that has no switch the window is up and I want to lower it. I was hoping there might be a way to put 12v directly to the motor from the switch connector?
(Post 52420774)
If you can access the motor in the tailgate from the inside and apply your ground and 12v that should work. ...
(Post 52420798)
^^^ implies that you are not trying to fix the window system but merely want to lower the window, so yes, This:
Disconnect existing connector from the motor. |
(Post 52420770)
with a battery hooked up to the 4runner I have no dash lights or for lights, I was hoping to add power to the console switch connector and be able to lower it but I'm guessing that's not going to happen for me.
(Post 52420804)
I believe that that switch on the console is for lock and unlock, not for raising or lowering the window. That is done by the lock in the tailgate.
Originally Posted by roughridn_sob
(Post 52420755)
OP worse case scenario but probably easiest is to pull the rear interior tailgate cover and jumper it from a car battery instead of chasing switches etc |
[QUOTE=dropzone;52420862]most 2nd gens have the switch to raise/lower rear window from the center console
Humm, Mine only has a lock/unlock switch, Am I missing a switch? There is an empty slot in the console and another wire harness laying there. My console has 3 slots, 1st is a coin slot, 2nd is the lock/unlock and 3rd is empty. |
